Windows 7: No sound again. Help me.
17 Aug 2010   #11
josef613
Windows 7 Ultimate 32-Bit
What happens if you go to the sound mixer and go to the levels tab?
17 Aug 2010   #12
angelinaxx
MS windows 7 home premium
so confused on why it wont work :/ ugh
17 Aug 2010   #13
josef613
did you try the sounds tab?
17 Aug 2010   #14
angelinaxx
17 Aug 2010   #15
josef613
ok, have you tried using headphones vs. the onboard speakers?
18 Aug 2010   #16
angelinaxx
no sounds ugh
Look at my other thread for more info. but basically i upgraded from windows XP to windows 7, on my gateway laptop and now there is no sound. it says the its installed and everything and when i play videos and click on the sound icon the bar moves up and down like the sounds works. i tried youtube everything NO sound. it does have sound when the machine starts up though.
just thought posting in this forum would help me get better answers.
18 Aug 2010   #17
Petey7
You said it has sound when starting up. When specifically do you hear sound from the computer?
18 Aug 2010   #18
Lemur
Download the latest sound driver for your notebook. Dunno if your gateway is 7327gz, or other letters...
Gateway Support - 4694*Gateway 7326GZ Notebook
Take a look at your Volume Mixer and be sure nothing is muted.
18 Aug 2010   #19
Aphelion
Windows 7 Home Premium
Also, right click Microsoft speaker icon in task bar, slect Playback Devices, make sure Speakers is set as your default device, select speakers and then the properties button at the lower right, if you have the Enhancements tab, select it then disable all enhancements select "Apply" and reboot.
Ap
06 Sep 2010   #20
lekennedy
windows 7 home premium x32
I had the same problem with no sound on a clean install of windows 7 on a 7326gz and had all the same screens that were shown in the replys. I could see everything should be working and just couldn't hear any sound. So here's what I did:
1. Download the xp audio driver 9528156 from Gateway Support Gateway Conexant Audio Driver Version: 6.13.10.8240 and save it to a folder or the desktop
2. Go to where ever you saved it and double click on the zipped file. This will extract the files to C:\cabs\9528156
3. Go to C:\cabs\9528156, right click HFXsetup and click on Run as Administrator. Clicking the Run as Administrator is the key here.
Once I did that I restarted my laptop and got sound.
The only thing I didn't get working as well is the video driver. My device manager still does not recognize the video controller but I'm quite happy with the default video driver that's in Windows 7.
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Distortion sound using onboard realtek sound card on windows 7ultimate
Hello,i recently upgrade my system from xp to windows7,i use the same realtek driver and get distortions!I try severall drivers,disable all enhancements/levels on speakers properties with no result(2.1speakers-),i configure them in stereo mode,i reduce the default format to 44100 16bits(cd...
Sound Control panel takes 2 minutes to open; HDMI sound inconsistent
Brand new Windows 7 Home Premium (6 bit) computer. When I click on the Sound control panel item, sometimes it takes 1-2 minutes to open. But that's kind of minor (although I'd like to know how to fix it), because sometimes the HDMI sound to my HDTV works fine, and sometimes it doesn't work at all....
narrator no sound - and sound vbs file no sound
I tried this file on my other win 7 and it works fine , but I have no sound with this file . and narrator has no sound also .. system sounds and mp3 's / movies sound good ... Ideas . thanks
Missing Sound Video & Game Controller in Device Manager, no sound
Hi Its bit complicated.:D I have 5 year old Compaq Pressario V3611AU notebook with AMD Atholon X2 TK-55 processor. Was using Windows XP and everything working fine. Recently I upgraded RAM to 2GB & processor was changed to AMD Turion(tm) X2 TL-60 2.00Ghz. I installed windows 7 and everything...
