Windows 7: No sound again. Help me.
17 Aug 2010   #1
angelinaxx
MS windows 7 home premium
So i recently just got a new laptop
It's a gateway 7326gz
It's designed for Windows XP BUT I downloaded a clean copy of Windows 7.
Everything is working, but the sound. Last time i upgraded and my dell didn't have sound there was a red line going through the sound icon. This time there is not. When i am on youtube or any other place i can click on the sound icon on the taskbar and it will have the bar moving up and down like the sound is working. When i start up windows the sound even works as i sign in. What is going on?
Here is a screen shot.
http://i35.tinypic.com/2la7v3s.png
Thank you in advance.
17 Aug 2010   #2
josef613
Windows 7 Ultimate 32-Bit
hmm, weird, so you can't hear sound after you log in?
17 Aug 2010   #3
Mellon Head
If you open the sound options panel from the task bar, what is your system volume set to?
Also, you might wanna take a look at that video driver hiccup I saw in your screen shot. It looks like a problem.
17 Aug 2010   #4
Lemur
Volume control options - plus like Mellon, I'm wondering about that video controller.
17 Aug 2010   #5
josef613
Quote   Quote: Originally Posted by npdgroupindore View Post
This is for all the forum members !
As this is the new product launched and I just want to introduce this on forum
specially for the electronics crazy forums.
This, I got after the extensive research on internet and I think that they are good and affordable.
Please have a look if it suits you. Thanks for the cooperation
eken m001
Please do not hijack this thread, it is rude and inconsiderate.
Start your own thread if you want to talk about something
17 Aug 2010   #6
Mellon Head
Quote   Quote: Originally Posted by josef613 View Post
eken m001
I reported it as spam already.
17 Aug 2010   #7
josef613
so did i
17 Aug 2010   #8
angelinaxx
it also shows this moving up and down but no sound... ugh
17 Aug 2010   #9
josef613
it seems that speakers isn't checked
17 Aug 2010   #10
angelinaxx
i went ahead and checked it too >.<
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Distortion sound using onboard realtek sound card on windows 7ultimate
Hello,i recently upgrade my system from xp to windows7,i use the same realtek driver and get distortions!I try severall drivers,disable all enhancements/levels on speakers properties with no result(2.1speakers-),i configure them in stereo mode,i reduce the default format to 44100 16bits(cd...
Sound Control panel takes 2 minutes to open; HDMI sound inconsistent
Brand new Windows 7 Home Premium (6 bit) computer. When I click on the Sound control panel item, sometimes it takes 1-2 minutes to open. But that's kind of minor (although I'd like to know how to fix it), because sometimes the HDMI sound to my HDTV works fine, and sometimes it doesn't work at all....
narrator no sound - and sound vbs file no sound
I tried this file on my other win 7 and it works fine , but I have no sound with this file . and narrator has no sound also .. system sounds and mp3 's / movies sound good ... Ideas . thanks
Missing Sound Video & Game Controller in Device Manager, no sound
Hi Its bit complicated.:D I have 5 year old Compaq Pressario V3611AU notebook with AMD Atholon X2 TK-55 processor. Was using Windows XP and everything working fine. Recently I upgraded RAM to 2GB & processor was changed to AMD Turion(tm) X2 TL-60 2.00Ghz. I installed windows 7 and everything...
