sound problem
  1. Posts : 206
    windows 7 64bit
    sound problem
    hi my sound volume keeps going down i set it to 50 and when i play music voloume goes back down again how can i stop this ???
  2. Posts : 3,139
    One possible solution. Go into safemode and delete the drivers first, then install latest drivers.
  3. Posts : 206
    windows 7 64bit
    how do i log in safe mode lemur ?
  4. Posts : 3,139
    Reboot your computer. Just before the Windows 7 loading screen shown above appears, press the F8 key to enter Advanced Boot Options. . You will see options, such as Safe Mode, Safe Mode with Networking, etc. Select Safe Mode. You can then go to Device Manager and delete your audio driver.
    Install your new audio driver. Reboot.
    Attached Thumbnails Attached Thumbnails sound problem-safemodewindows72_thumb.jpg
  5. Posts : 206
    windows 7 64bit
    ok lemur i did wat u said ill go play with it then see if volume stays stedy fingers crossed.
  6. Posts : 206
    windows 7 64bit
    no didnt work recording voluem still going down i set to 100 went down back to 20 why does dis happern?????????
  7. Posts : 3,139
    I cannot vouch for this software, but it's certainly worth a shot. It LOCKS the volume. 14-day free trial from a reputable download site:
    VolumeLock - Free software downloads and software reviews - CNET Download.com
    Please let me know how this goes. :)
  8. Posts : 206
    windows 7 64bit
    im gonna try delet sound one more time but dis time im gonna use driver sweeper.
  9. Posts : 206
    windows 7 64bit
    ok lemur im going to download the programe you suggested and ill let you know wat happens.
  10. Posts : 206
    windows 7 64bit
    ok lemur i download the programe and started using it im not 100% sure if im using the program propley but still voice is going down ???
