Windows 7: help,audio prob
26 Aug 2010   #1
khafanizm
7 ultimate
help,audio prob
recentlly i installed a win 7 on my laptop,there was no sound and the media playered said i have problem,i downloaded the latest version of realtek hd driver ,now the media player works but theres still n o sound.what should i do
26 Aug 2010   #2
Lemur
Welcome to SF, khafanizm!
First, please list information under system specs.
Second, was this an upgrade from a previous operating system? Need system specs (be specific) before we can go on. Thanks!
26 Aug 2010   #3
Lemur
Just jumping the gun, make sure your sound mixer isn't muted. And check your device manager for any audio warnings.
26 Aug 2010   #4
khafanizm
7 ultimate
Quote   Quote: Originally Posted by Lemur View Post
no that driver wasent for win7 ,was for xp,i downloaded it from realtek site
26 Aug 2010   #5
khafanizm
7 ultimate
and its internal
26 Aug 2010   #6
Lemur
A8 has EZxx, STxx or S8xx afterward. Please go to:
Toshiba Support - Homepage
and download the appropriate audio driver.
You didn't specify 32- or 64-bit operating system.
Might as well update all your drivers.
Then make sure the sound is not mute, look at Event Manager for any yellow warnings, and let us know. Good luck!
 help,audio prob
games resolution prob..cut off prob
when i start my games like nfs most wanted ,gta san andreas ,counter strike ,prince of persia -the sand of times....my screen is cut off from both the sides... am having out 64 bit windows 7 plz help sort this prob....i tried everthing bt nothing works..:cry::(
Gaming
HDD Prob....
Hi all. I'm new to SevenForums and I want get 7. I have XP so I will set a dual-boot and there's a problem.. I have the 7 ISO and the way to install it, but when I tried to create another partition in the unallocated space on my drive, I get surprised when I see a blank screen in Disk...
General Discussion
BT prob
i used my BT device with da default Windows 7 BT driver n software etc....then i installed IVT BlueSoliel....n after dat the blutooth icon from my control pannel dissapeared..! i uninstalled it but it was no use... now i cant use BT on my Windows with or without da software(Bluesoliel)..!!! plz...
Drivers
Multiple Monitor prob and audio prob as well
Hey All First post here, I did a search and did not find any specific answer to my problem. Firstly I am running Win 7 Ultimate with an Nvidia 8600 GT video card running HDMI through the SPDIF output to the graphics card. My problem is getting my pc to duplicate to my HDTV when I hit the...
WMC and DVD Prob
I tried watching some DVD's on Windows 7 with Media Center and all the movies look like this (Pic Below) do I need to download something? They seam to play fine with VLC
Media Center
