No 5.1 Audio in Realtek HD Audio Manager
  1. Posts : 9
    Mac OS X Leopard, Windows 7 Ultimate x64
    I have five speakers and one subwoofer connected to a Samsung HT-Z310 DVD-player, and then connect that to my MacBook using AUX 2.
    (I have no idea what AUX 2 is, but that's what the tiny display on the DVD-player says.)
    The problem is that the Mac only plays stereo on them.
    When I open Realtek HD Audio Manager, in the "Speakers" tab, and the "Speaker Configuration" subtab, "Speaker Configuration" is set to "Stereo" by default. And it's grayed out, so I can't change it.
    Further than that, I only have two options: "Full-range Speakers" - "Front left and right" and "Headphone Virtualization".
    I have also tried "Control Panel", "Hardware and Sound", "Sound", marking the speakers and clicking "Configure", but the only option displayed in the list is "Stereo".
    I have no idea what's wrong. The rear speakers work, but play the same sound as the front speakers.
  2. Posts : 9
    OK, so after thinking about it for a while, is it possible that my sound card doesnt't support 5.1 audio?
  3. Posts : 14,606
    What kind of cable are you using from macbook to dvd player?
  4. Posts : 14,606
    Aux means Auxiliary
  5. Posts : 9
    A Minijack cable that splits into one red and one white tip.
  6. Posts : 14,606
    Ok so 3.5 jack to left and right phono ,i think as you are running the output cable that is stereo only then that is what your DVD player receives.
    Is there a setting on the DVD player to convert stereo signal to a surround signal . i have a Technics home theater and my pc plugs into that, i still get a surround sound but its forced by the amp.
  7. Posts : 9
    The DVD Player is set to Matrix if that's what you mean.
    All the speakers make sound, but only stereo. In the "Configure speakers" interface there are only two speakers I can click, but if I click the one to the right, both the front right and rear right speakers make sound. The subwoofer and the middle speaker also work.
