No Audio Output Device Installed
Page 3 of 4 FirstFirst 1234 LastLast
  1. Posts : 1,614
    Windows 7 Pro & Vista Home Premium
       #21
    First, could you give me your motherboard specs?
    You might need the audio codec along with the driver:
    Realtek
    Go to Device manager click on the audio driver with the yellow flag abd choose uninstall.
  2. Posts : 2
    Windows 7 Pro
       #22
    Problem solved!
    I downloaded and installed the driver in the one before last reply on this thread: HP pavilion dv5000 audio driver - Windows® 7 Beta and test - HP Support Forum
    Thanks for the very quick reply all the same though, just installed 7 today and I think I've found the best forums online for it.
    Huw32
  3. Posts : 13
    windows 7
       #23
    Huw32 said:
    Problem solved!
    Huw32
    please help....i have the same problem and laptop....i downloaded that link but no sound! ><
  4. Posts : 13
    windows 7
       #24
    Huw32 said:
    Problem solved!
    Huw32
    please help....i have the same problem and laptop as the one in the link....i downloaded that link but no sound! ><
  5. Posts : 1,614
       #25
    Is it the exact same model number?
  6. Posts : 13
    windows 7
       #26
    yup....exact same model number, i just checked lol
  7. Posts : 1,614
       #27
    Do you receive any error massages.
    Go to Control Panel > Devoice manager and see if any items have a yellow flag.
  8. Posts : 13
    windows 7
       #28
    yes there was a yellow triangle.
  9. Posts : 1,614
       #29
    Right-click on that entry and choose remove or uninstall.
    Reboot Windows and it may have a driver for you
  10. Posts : 13
    windows 7
       #30
    nothing worked......i'll just wait til next week when my brother gets his free windows 7 upgrade.
