How do you get sound to come out of second monitor?
  1. Posts : 132
    7 Ultimate x64, Windows 7 Enterprise x64
    I connected my laptop to my monitor with a vga cable (since thats the only connector that the laptop has), but for some reason, sound is not coming out of the monitor. how should i fix this? i know that the speakers work, since i once got sound out of them, but have never used the speakers since
    my monitor is this one
  2. Posts : 6,879
    Win 7 Ultimate x64
    Unless you threw it out or misplaced it that monitor should have come with an audio cable, you have to use it connected to the monitor and the headphone/speaker jack on the laptop to get sound on the monitor.
  3. Posts : 132
    the audio cable is for the dvi cable, but i tried that, and it didnt work
  4. Posts : 6,879
    Win 7 Ultimate x64
    No the audio cable is required whether you connect it via DVI or VGA as neither of those can send audio. The only way to get audio to that monitor without it is to use HDMI, and then the HDMI port from the video card has to be able to send audio.
    When that cable is connected it should have auto switched to the headphone/speaker jack from the laptops internal speakers, but it doesn't always work as planned. Double check the audio settings and make that it is switched to headphones/speakers and not still on the laptop's own speakers.
  5. Posts : 132
    Weird. Now it works. Cool! Thanks!
  6. Posts : 1,074
    Windows 7 Profession 64-bit
    What did you do to fix it?
  7. Posts : 132
    i just plugged the sound cable in and started messing around with the sound configuration until sound came out of the monitor
  8. Posts : 132
    I still have a slight problem: the sound coming from the monitor is very low, even though everything is at max, but on my laptop, the sound is very loud. Would this be a sound card/speaker difference?
  9. Posts : 1,074
    Well, if the notebook speakers plays it loud, but your monitor will not amplify it more, then you are probably out of luck.
