problem with sound cracking in USB DAC when watching video files
  1. Posts : 55
    windows 7 professional 64 bits
    Hi all,
    I have a problem with my USB DAC in my media center PC, and I would be delighted to receive your help
    When I play music everything works perfectly. However, when I play some video files in WMC the audio cracks continously, it becomes unacceptable and I have to quickly stop the video for not damaging the speakers. It also happens when resizing the video screen or switching to full screen mode.
    The DAC is a MUSILAND MD10, which uses the generic USB audio DAC driver from Microsoft.
    In order to check if the problems were linked to this USB MUSILAND DAC setup, I have also installed another USB soundcard EMU 0404, which uses its own driver. I can confirm no cracks occur when using the EMU.
    So, this is nothing related to windows process running in parallel or system load.
    Could it be the windows 7 USB audio DAC driver? I tried to update if from the dev manager but it has the latest. Any thoughts?
    Thanks a lot!!!
  2. Posts : 55
    Hi again,
    I have installed the ASIO4ALL driver in the PC. In order to play the files in WMC and WMP I have also installed the ASIO plugin for WMP. However, when I try to play an audio file I get the following error:
    "ASIOWmpPlg: Failed to create ASIO interface, error code 80004002,"
    I seem to have 2 problems now: how to use ASIO4ALL in WMP in win7 PC, and the annoying cracking sound...
    cheers
  3. Posts : 55
    hi all,
    Just in case someone can understand what is going on in my PC with the audio, I will add up more findings of the problem.
    I have downloaded VLC media player, and every single avi I played had perfect audio using my MUSILAND DAC player.
    So, the problem is down to the use of the MUSILAND DAC player in WMP/WMC.
    As mentioned in previous posts, if an EMU USB card is used in WMP/WMC, everything OK. Also, installing ASIO4ALL in WMC throws an error.
    Any thoughts?
    Cheers
  4. Posts : 55
    More findings...
    I have grabbed the USB DAC, and I have connected it to a laptop with same WIN 7 OS version as the media center PC
    First, I can use the ASIO driver in WMP.
    Second, the audio does not complain with the same video files I played in the media center PC.
    Also, I have tested using WMP/WMC in the media center PC with the onboard sound card. It also played without problems
    In summary, the problem is when I use WMC /WMP in the media center PC with that USB DAC....
    I am lost............Help pleaseeeeeeeeeee
  5. Posts : 55
    It is me again...
    I reinstalled WMP using the windows features control panel, and I still have the same problem...
    going mad...
  6. Posts : 55
    Hi, it is me again!!! I know, I am very stubborn:)
    I am stilll trying to make some sense of my PC audio problem...
    I have reinstalled windows, and now I am even more confused... Now, if I play an aVI file in WMP using the USB DAC for playing the audio, everything is fine, which made me thiniking the problem was gone...
    However, if I play the same file with WMC I have the same crakling probrem with the audio as I had before restarting...
    How can that be possible? I thought that WMC was using WMP audio and video API and codecs....
    I am not being too lucky... Does anybody have an idea of what is going on?
    Thanks!!!
