Windows 7: Sound problem
08 Sep 2010   #1
kennyan
windows ultimate 32-bit
Sound problem
Hello!
My problem is this:
When my speakers are connected directly to the soundcard they don't play any sound. But when i plug it via the headphones connection all works fine.
Also to mention is that I run a dual boot with Ubuntu and there the speakers work fine directly in the sound card, weird.
Thanks for any help
08 Sep 2010   #2
PooMan UK
Windows 7 Ultimate 64bit
Hiya pal and welcome to the forums
Click right mouse button on the speaker by the time. Goto playback devices, you will get and option like in the pic below. Select your soundcard as the default device if you want to hear sound from your speakers or select your headset if you want to hear the sound from your earphones.
11 Sep 2010   #3
kennyan
Solved
Thank you for the help!
11 Sep 2010   #4
PooMan UK
No probs pal, glad to hear you got it sorted
 Sound problem
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Sound problem perrsists even after new sound card
As some of you might remember, a few weeks ago I had a problem with sound after I built a new PC and kept my old Win 7 installation using sysprep: https://www.sevenforums.com/sound-audio/280175-onboard-sound-issue-new-pc-build-2.html#post2308990. The problem was that the volume levels were off, and...
Sound Problem
I have tried to play mpegs and Avi files on Nero Showtime (Nero 7 ) and also on Divx 8, Realplayer and Quicktime but I get no sound. I do get sound on Win Media Player only. I installed Klite codec pack for Win 7 64bit. Do I have to install the 32bit codec pack for the 32bit programs to...
Sound problem - need to 'scan for hardware changes' to get sound
Hi everybody I have a fairly strange problem with my Laptop. It came originally with Vista and a while ago I updated to Windows 7 32bit Home Premium. Since then I don't have any sound after booting the Laptop. By chance I found out that when I go into the device manager, right click on the sound...
Hardware & Devices
Windows Media Player Problem - Sound/skipping problem.
Oh look, another windows media player problem, lol. Well, it's something really weird, at first i thought it was just my computer being all slow or the file was messed up, No matter what movie or format i play it makes this weird screeching noise. It also lags pretty bad. I tried the scans, i did...
Music, Pictures & Video
