onboard sound vs. Addon sound card
  1. Posts : 2,240
    Windows 7 Ultimate 64 bit
    What would be the advantages/disadvantages of onboard sound vs a sound card? With a sound add on card are there headers for front panels connections.? Would I see/hear a big difference in the sound?
    It would depend on what you want from the audio or what applications you have for it. I have a home built using an Intel motherboard that has IDT (SigmaTel) HD audio on it. It's fine for most of the "listening" that I do However, I have a music program that uses MIDI and the default built in Windows/Microsoft GS Wavetable MIDI Synth is pretty bad. For that reason I have a SoundBlaster Xfi installed and SoundBlaster has on board hardware MIDI synths that are much better.
  3. Posts : 3,139
    Typically, you can get a higher-end device with a sound card. If you wanna have a surround sound-type experience, then you might consider a card:
    Newegg.com - ASUS Xonar Essence ST 24-bit 192KHz PCI Interface Audio Card
    If you are gonna put your audio through $15 speakers, then forget the card and use the onboard audio chip.
  4. Posts : 31,250
    Depends on what you are looking for and as always what you are prepared to pay for it :)
    To be realistic for most purposes the on-board chip's on today's systems are perfectly adequate for most peoples needs, if you are a serious audiophile or looking to use the pc for professional sound production, even DJing, that the flexibility and quality of add on external units are probably worth the extra cost and installation. In fact if you are a dj an extra card is virtually essential to allow off-line cueing etc.
      My Computers
  5. Posts : 6,879
    Win 7 Ultimate x64
    Another age old debate. Here is a thread on this very subject that is over 4 years old and up to 600 posts now,
    Onboard Sound Vs. Add in Sound Card - Guru3D.com Forums
    So very true. Also if your going to use a digital connection (coax or optical, doesn't matter), then unless there is a feature that is on a sound card over onboard (DDL for example) just use onboard as it then comes down to what is connected at the other end.
