No sound with 4GB memory on the laptop
  1. Posts : 10
    Windows 7x64bit
    I have an Compaq CQ40 Laptop and today I changed the memory from 1GB to 4GB but after upgrade I do not have sound at all even if the hardware is ok and fully functionally. I took one af the sticks and put the old 1GB stick and is working Now the problem is when I put both 4gb i do not have sound but with 3 GB I have. It is anything what I can do to make the Windows 7 64-bit to have sound with 4GB memory?
    Thank you!!
  2. Posts : 3,139
    Please see if there is a bios upgrade for your mobo. Also upgrade you sound card driver.
    Thats a bios issue.. is PAE enabled?
  4. Posts : 10
    Windows 7x64bit
    Thank you. I will see what BIIOS updates are and I let you know about the results.
  5. Posts : 3,139
    ASUSTeK Computer Inc.-Support-
    P5Q Deluxe BIOS 2301
  6. Posts : 670
    Windows 7 x64
    Thank you!!
    Are the memory sticks the same brand and matching?
    While no sound with 4 Gb installed, what does device manager show for the sound, any yellow marks next to it? Have you tried reinstalling the sound driver?
    Welcome to the forums.. pretty apt question for a first post.... but it's not really necessary to match brands of memory, so long as they both have the same clock speed and within manufacturers' specs,
  8. Posts : 10
    Windows 7x64bit
    Sorry mate but is about an laptop.
  9. Posts : 10
    Windows 7x64bit
    I did it!! It was from BIOS. It needed an update and now it is working.
    Thank you!!
    wtg and now that it's done, we'd be very irresponsible not to warn you about upgrading bios.. one wrong move, like a loss of power or a system freeze and your system becomes an expensive doorstop.
