Sound control
  1. Posts : 9
    win7
    Sound control
    Hi there,
    in my laptop (asus) i have keys to control the sound (FN+ f10-f11-f12), enable/ disable and up and down the volume, but since i get win7 i cant control them...
    i press the Fn+f11 appears the pics below but nothing happen...
    i instal the sound drivers realtek but still the same...
    Help pls
    In the realtek audio manager i also cant control de sound up ou down...
  2. Posts : 1,797
    Windows 7 Ulti. x64
    hello, have you tried,control panel/ device manager/system devices/ACPI/ right click and update drivers select automatic. I have not tried this so be sure you have a system restore point before trying just in case you need to go back if changes donot work for you. System Restore Point - Create
  3. Posts : 620
    7264x64/7260x86
    You gotta install the ACPI drivers as well.
    Go to asus's site and get them, I'd be surprised if you can get them from windows update.
  4. Posts : 9
    win7
    i try what myzr7 said and dont work...
    i go to asus and dont find acpi drivers...
    i do a search on google and download a pack of controler which said include uaa try to install,appears something saying that ,that pack is not for my realtek...
    grrrrrrrrr...
    dont know wt to do more...any more ideas...???please
  5. Posts : 620
    7264x64/7260x86
    What model is your laptop? The ACPI drivers for my asus netbook were under ATK section.
  6. Posts : 9
    win7
    Boas!
    copernicus my laptop asus is a A6JC nvidiaGF 7300
    Audio is a realtek...
    u had the same problem??
  7. Posts : 620
    7264x64/7260x86
    Try installing the ACPI from under the ATK section here:
    ASUSTeK Computer Inc.-Support-
  8. Posts : 9
    win7
    Copernicos did u have win 7 instaled? first which OS i choose??win 7 is not on the list...
    Which atk driver did u instal for sound control?
    i need to change compatibility?
    sorry but i dont get
    how to put my sound control working
  9. Posts : 620
    7264x64/7260x86
    Choose vista 32 and run the setup.exe you will get from inside the zip file. It may run normally, if not run it in compatability mode.
    The hardware keys are driven by the acpi drivers. I had to do the same thing for my 1000he to get most of the keys working.
  10. Posts : 9
    win7
    Well i instal the drivers and it work for the first time...
    but after reboot dont work again...
