Windows 7: No audio output device, not responding to anything i have read on here
29 Sep 2010   #1
bdmedlen
Windows 7 home premium
I go to the cp, and go to the device manager and click on my sound devices, ATI High Definition Audio Device and IDT High Definition Audio CODEC, both have the yellow triangles. I disabled them and then enabled them but to no prevail. In the device status it gives me this message,
"Windows cannot verify the digital signature for the drivers required for this device. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source. (Code 52)"
If I could get some help that would be great.
thanks
30 Sep 2010   #2
fireberd
See THIS on disabling the driver signing. That fixed a CD drive problem and maybe will also fix the audio problems.
30 Sep 2010   #3
bdmedlen
[f8] on boot up did nothing.
30 Sep 2010   #4
fireberd
When did you press F8? It has to be pressed BEFORE Windows starts to load. You should get a menu with several options.
No Audio Output Device Installed Error (Code 52 on my audio devices)
Hello there, I have an error in my Windows 7 with the audio, "No Audio Output Device Installed." I checked the playback & recording devices, but none are installed. I checked for hidden devices, but there wasn't any. So I opened the Device Manager, and checked the "Sound, video, and game...
No Audio Output Device is installed, HDMI Audio Out Works
No sound. Little speaker with the red 'x' appeared yesterday I have gone through the whole update drivers circus to no avail, my laptop can't detect that it has speakers built in so it doesn't bother finding a driver for them. This is where I am at: - Intel Display Audio is the only driver...
Realtek Audio: No Audio Output Device is Installed
Hello. Im having the dreadful "No Audio Output Device is Installed" problem on my realtek audio. It worked some months ago, but im in no position to do a roll back. Im sure the hardware is just fine, it works with Ubuntu. The computer is a Dell Vostro 430. My OS is win7 64bit. I tried...
I have a Dell XPS M1330 with Intel Core Duo 2 and my OS is Windows 7 64 Bit. I have tried downloading drivers, windows updates, virus scans, browsed different forums for a solution, but none of them worked.. My sound just isn't working and I don't know what to do next. My SigmaTel High Definition...
NO audio output device
anyone help me.. i changed my os from xp to windows 7... but now same as the problems of the others, no audio output device with a red mark on the icon.. i just installed the cd windows 7. i cant install my graphics card because it says it's not supported with windows 7.. so i can open windows...
