No voice from the monitor straight
Hi, I have problems with no sound. At the beginning I installed the software Win7 some years ago, everything worked well was the sound and well played. A few months after he disappeared. Recently I took in for repair, because sound patterns began to hide. After repair, I turned kompa and still have no voice, of course, the reins are all installed. I do not want to install the reins once again. And I see the bar on the right is the proclaimed at 100% and play well. The socket is connected to the green. But there is no voice. What should I do?
I am counting on your help, I do not know where to start ...
EVEREST Report:
Computer:
Computer Type ACPI x64-based PC
Operating system Microsoft Windows 7 Ultimate
Service pack of the operating system -
Internet Explorer 8.0.7600.16385
DirectX DirectX 11.0
Computer Name BRONKA-COMPUTER
Username Bronka
Logon Domain Bronka-Computer
Date / Time 2010-10-09 / 23:20
Motherboard:
CPU Type DualCore AMD Athlon 64 X2, 2200 MHz (11 x 200) 4200
Name of MSI K9N Neo v2/v3 (MS-7369) (3 PCI, 2 PCI-E x1, 1 PCI-E x16, 4 DDR2 DIMM, Audio, LAN)
Motherboard Chipset nVIDIA nForce 560, AMD Hammer
Physical Memory 3072 MB (DDR2 SDRAM)
DIMM1: AET660UD00-30DA98Z Aeneon 512MB DDR2-667 DDR2 SDRAM (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz) (3-3-3-9 @ 200 MHz)
DIMM2 Patriot 6400LL Series Memory 1 GB DDR2-800 DDR2 SDRAM (5-5-5-16 @ 400 MHz) (4-4-4-11 @ 266 MHz) (3-3-3-8 @ 200 MHz)
DIMM3: AET660UD00-30DA98Z Aeneon 512MB DDR2-667 DDR2 SDRAM (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz) (3-3-3-9 @ 200 MHz)
DIMM4 Patriot 6400LL Series Memory 1 GB DDR2-800 DDR2 SDRAM (5-5-5-16 @ 400 MHz) (4-4-4-11 @ 266 MHz) (3-3-3-8 @ 200 MHz)
BIOS Type AMI (03/17/09)
Port Communications Port (COM1)
Communication Port Printer Port (LPT1)
Display:
Video card ATI Radeon X1950 GT (256 MB)
3D Accelerator ATI Radeon X1950 GT (RV570)
Monitor HP w2007 [20 "LCD] (CNN7273GC1)
Multimedia:
Sound Card nVIDIA MCP65 - High Definition Audio Controller
Magazine:
IDE Controller Standard Dual PCI IDE Controller
Floppy Drive Floppy disk
Physical Disk ST3250620AS ATA Device (250 GB, 7200 RPM, SATA-II)
Optical Drive HL-DT-ST DVDRAM GSA-H42N ATA Device (DVD R9: 10x, DVD-R9: 10x, DVD + RW: 18x/8x, DVD-RW: 18x/6x, DVD-RAM: 12x, DVD-ROM : 16x, CD: 48x/32x/48x DVD + RW / DVD-RW / DVD-RAM)
SMART Hard Disks Status OK
Partitions:
C: (NTFS) 76489 MB (47373 MB free)
D: (NTFS) 79297 MB (72903 MB free)
E: (NTFS) 82686 MB (67950 MB free)
Total Size 232.9 GB (183.8 GB free)
Input:
Keyboard Standard PS / 2
Mouse Microsoft PS / 2
Mouse HID-compliant
Network:
Primary IP address 192.168.1.100
Basic card address (MAC) 00-19-5B-EB-3A-E4
Network card D-Link AirPlus Xtreme G DWL-G510 Wireless PCI Adapter (rev.C) (192.168.1.100)
Realtek GbE Controller Family
Peripherals:
Fax Printer
Printer Microsoft XPS Document Writer
Printer Send To OneNote 2010
USB1 Controller nVIDIA MCP65 - OHCI USB 1.1 Controller
USB2 Controller nVIDIA MCP65 - EHCI USB 2.0 Controller
Universal USB Device USB printer
Input Device USB Device USB
DMI:
DMI: Manufacturer American Megatrends Inc. BIOS.
DMI: BIOS version number v2.9
DMI (system): Manufacturer MSI
DMI (system): the name MS-7369
DMI (system): version 1.0
DMI (system) Serial Number To Be Filled By OEM
DMI (motherboard): Manufacturer MSI
DMI (motherboard): the name MS-7369
DMI (motherboard): version 1.0
DMI (motherboard) serial number To be filled by OEM
DMI (housing): Manufacturer To Be Filled By OEM
DMI (housing): the version number To Be Filled By OEM
DMI (housing): Serial Number To Be Filled By OEM
DMI (housing) asset tag To Be Filled By OEM
DMI (housing): Type Desktop Case
DMI (memory): the total number / number of free gniazd4 / 0
