Help Me Pleaseee :(:(:(
i have a other soundcard of pc and i need for driver for windows 7 ultimate 32 bit
the driver webpage is MS-Tech Europa GmbH | Download
but in this page not soundcard driver for windows 7
help mee pleaseee
help mee pleaseee
I tried vista but the same problem
Use the vista driver if they have one and you should be OK...
Be sure to install it in Compatibility Mode..
How to Run a Program in Compatibility Mode in Windows 7
can you speak albanian beacues i cant speak good english :$
shofer pėrdorin pėr Windows Vista
I tried the vista of the three methods is the same problem again :s
Can you use the on-board sound?? if not, then you may need to replace the card with one that is compatible with windows 7.;
but i just thought how I bought not there any solution: S
