Windows 7: Window 7 audio not working please help !!
19 Oct 2010   #101
brianzion
this may be it lets see
http://***************/files/425969180/Realtek.zip
19 Oct 2010   #102
ipodtouchme
Window 7 Ultimate 64bit
so what do i do with it after i got it ?
19 Oct 2010   #103
brianzion
Quote   Quote: Originally Posted by ipodtouchme View Post
the first one open the zip and you should see a file called set up click this
19 Oct 2010   #104
ipodtouchme
Quote   Quote: Originally Posted by brianzion View Post
yeah install it and now it says restart comp so i restart yeah ?
19 Oct 2010   #105
brianzion
the set up is the windows installer
19 Oct 2010   #106
brianzion
yep
19 Oct 2010   #107
ipodtouchme
yeah i setup so i restart comp now
done install and that now what sir ?
19 Oct 2010   #108
ipodtouchme
hey brianzion still there ? i install it
19 Oct 2010   #109
brianzion
when you pressed the set up did you get the installer screen up?
19 Oct 2010   #110
ipodtouchme
yeah it did
Audio on computer displays it's working but no audio is coming through
I recently encountered this problem I was on windows 10 but I decided to do a fresh install mind having to put over like 6,000 files on to a uploading website cause I do youtube, editing etc whatever and so it first started out as like when I would max out the speakers it would do like a...
Laptop speakers working, but headphone jack not working only on Window
Hi, I have a dual boot of Fedora and Windows, and when I boot into Fedora, my headphones work fine. When I boot into Windows 7 64bit, my headphones don't work. My laptop speakers work fine however, and I tried re-installing drivers. I made sure that my headphones are the default playback...
Realtek audio, Gigabyte mobo: strange-sounding audio, mic not working
I have a self-assembled desktop PC - full specs in the signature below, but in short, it has an AMD Phenom II X6 1090T processor on a Gigabyte GA-970A-DS3P mainboard, which uses a Realtek Azalia ALC887 on-board sound system. I have no loudspeakers and listen to the computer sound exclusively...
Asus onboard audio no longer working since enabling front panel audio.
My audio rear outs used to work, but even so, i was primarily using hdmi out from my video card. I was also diagnosing BSODs at the time and sent my mobo back to asus for an rma. When it got back, I placed it in a different case and attached the font panel audio. Due to a new living...
Onboard audio not working and audio drivers won't install
Hello everyone, I'm having a problem using my motherboardís onboard HD audio instead of my video cardís audio, so without further ado here is the situation; I have an Asus maximus iii gene motherboard which has a SupremeFX X-Fi built-in sound card (this is a very nice card provided you can...
