Windows 7: Window 7 audio not working please help !!
19 Oct 2010   #121
brianzion
Quote   Quote: Originally Posted by ipodtouchme View Post
Quote   Quote: Originally Posted by brianzion View Post
do i have to unistall the ac97 and realtek high definition audio ver 6.0.5898 ?
no because its all part of it see if you can open it from zip file
alright i got it i extract it i tried to use it nothing is poping up
maybe it just wont work it has to be installed click the volume icon
19 Oct 2010   #122
brianzion
i have aasked the fellow gurus for help on this for you:)
19 Oct 2010   #123
ipodtouchme
Window 7 Ultimate 64bit
yeah i click on it even run it on admin nothing pop up
19 Oct 2010   #124
ipodtouchme
thank you it will be helpful
19 Oct 2010   #125
brianzion
sorry mate we may get some help in s bit
19 Oct 2010   #126
brianzion
run the connections through me again on the pc you are using the sound to come out from you normally have a sound manager to help you
19 Oct 2010   #127
ipodtouchme
how do i run the connection through you again ?
cant we use team viewer so u can control my computer and see what u need to see ?
19 Oct 2010   #128
brianzion
19 Oct 2010   #129
brianzion
okey dokey i will download it
19 Oct 2010   #130
ipodtouchme
doesnt work no driver ....
Audio on computer displays it's working but no audio is coming through
I recently encountered this problem I was on windows 10 but I decided to do a fresh install mind having to put over like 6,000 files on to a uploading website cause I do youtube, editing etc whatever and so it first started out as like when I would max out the speakers it would do like a...
Laptop speakers working, but headphone jack not working only on Window
Hi, I have a dual boot of Fedora and Windows, and when I boot into Fedora, my headphones work fine. When I boot into Windows 7 64bit, my headphones don't work. My laptop speakers work fine however, and I tried re-installing drivers. I made sure that my headphones are the default playback...
Realtek audio, Gigabyte mobo: strange-sounding audio, mic not working
I have a self-assembled desktop PC - full specs in the signature below, but in short, it has an AMD Phenom II X6 1090T processor on a Gigabyte GA-970A-DS3P mainboard, which uses a Realtek Azalia ALC887 on-board sound system. I have no loudspeakers and listen to the computer sound exclusively...
Asus onboard audio no longer working since enabling front panel audio.
My audio rear outs used to work, but even so, i was primarily using hdmi out from my video card. I was also diagnosing BSODs at the time and sent my mobo back to asus for an rma. When it got back, I placed it in a different case and attached the font panel audio. Due to a new living...
Onboard audio not working and audio drivers won't install
Hello everyone, I'm having a problem using my motherboardís onboard HD audio instead of my video cardís audio, so without further ado here is the situation; I have an Asus maximus iii gene motherboard which has a SupremeFX X-Fi built-in sound card (this is a very nice card provided you can...
