Windows 7: Window 7 audio not working please help !!
19 Oct 2010   #131
brianzion
team viewer ready look in your pm messages
19 Oct 2010   #132
brianzion
the hdmi audio device? you dont need that?
19 Oct 2010   #133
Dwarf
Windows 8.1 Pro RTM x64
Hi ipodtouchme,
Your motherboard, Asus P5Q SE2, uses VIA audio. Drivers for other audio devices such as Realtek will not work. Here is a link to the latest audio driver for your motherboard from Asus: ASUSTeK Computer Inc.-Support-
19 Oct 2010   #134
brianzion
Quote   Quote: Originally Posted by Dwarf View Post
Hi ipodtouchme,
thanks dwarf i just been having a look at his system using team viewer and realized so i uninstalled his card drivers and told him to take out and re sit the cards and restart windows and let windows reinstall the drivers best remind him to get rid of the realtek thanks again
19 Oct 2010   #135
ipodtouchme
Window 7 Ultimate 64bit
Hi ipodtouchme,
Yeah i already download and install that software but still no work. it only makes the sound of a dead radio.
19 Oct 2010   #136
ipodtouchme
Ill be back in 4 hours i have work
19 Oct 2010   #137
Techymike
windows 7 home premium 64, and Windows 10 64 bit
Just curious, did you uninstall and delete all the realtek stuff? Then reinstall the card with the the new drivers?
19 Oct 2010   #138
ipodtouchme
Quote   Quote: Originally Posted by Techymike View Post
umm nope i havent unistall and delete all the realtek stuff, i was told to uninstall my graphic card and the sound driver and let the windows do the installing.
20 Oct 2010   #139
ipodtouchme
I uninstall and delete all the realtek, and i reinstall the graphic card and now i just install my motherboard latest audio driver which is "via audio". Now my speakers is making the same sound like last time "a dead radio without any signal". the audio seems working but theres no sound comming out as you can see in the picture.
still need help .....
20 Oct 2010   #140
brianzion
Hi ipodtouchme,
have you tried this post by dwarf
Audio on computer displays it's working but no audio is coming through
I recently encountered this problem I was on windows 10 but I decided to do a fresh install mind having to put over like 6,000 files on to a uploading website cause I do youtube, editing etc whatever and so it first started out as like when I would max out the speakers it would do like a...
Laptop speakers working, but headphone jack not working only on Window
Hi, I have a dual boot of Fedora and Windows, and when I boot into Fedora, my headphones work fine. When I boot into Windows 7 64bit, my headphones don't work. My laptop speakers work fine however, and I tried re-installing drivers. I made sure that my headphones are the default playback...
Realtek audio, Gigabyte mobo: strange-sounding audio, mic not working
I have a self-assembled desktop PC - full specs in the signature below, but in short, it has an AMD Phenom II X6 1090T processor on a Gigabyte GA-970A-DS3P mainboard, which uses a Realtek Azalia ALC887 on-board sound system. I have no loudspeakers and listen to the computer sound exclusively...
Asus onboard audio no longer working since enabling front panel audio.
My audio rear outs used to work, but even so, i was primarily using hdmi out from my video card. I was also diagnosing BSODs at the time and sent my mobo back to asus for an rma. When it got back, I placed it in a different case and attached the font panel audio. Due to a new living...
Onboard audio not working and audio drivers won't install
Hello everyone, I'm having a problem using my motherboardís onboard HD audio instead of my video cardís audio, so without further ado here is the situation; I have an Asus maximus iii gene motherboard which has a SupremeFX X-Fi built-in sound card (this is a very nice card provided you can...
