Windows 7: Window 7 audio not working please help !!
20 Oct 2010   #141
Dwarf
Windows 8.1 Pro RTM x64
So you're getting some form of white noise through your speakers? Does the noise seem to change depending on what sound you are trying to play?
20 Oct 2010   #142
ipodtouchme
Window 7 Ultimate 64bit
Quote   Quote: Originally Posted by brianzion View Post
Quote   Quote: Originally Posted by Dwarf View Post
Hi ipodtouchme,
Your motherboard, Asus P5Q SE2, uses VIA audio. Drivers for other audio devices such as Realtek will not work. Here is a link to the latest audio driver for your motherboard from Asus: ASUSTeK Computer Inc.-Support-
have you tried this post by dwarf
yeah thats what i did its shown in the attachment
20 Oct 2010   #143
brianzion
this is from the asus help page ASUSTeK Computer Inc.-Support-
Audio is abnormal
1. Abnormal input/output
1.1 There is yellow question mark before the audio device in Device Manager
1.1.1 Please install the patch "MICROSOFT UAA Function Driver for High Definition Audio" for the
OS firstly
1.1.2 Re-install the audio driver to have a try
1.2 There is yellow exclamation mark before the audio device in Device Manager
1.2.1 Un-install all the drivers related to the audio device,firstly, please install the patch
"MICROSOFT UAA Function Driver for High Definition Audio" for the OS
1.2.2 Restart the PC, if the problem still persists, please recover the system or re-install the OS and
load the latest driver for the audio device to have a test
1.3 The audio device could not be recognized in Device Manager
1.3.1 Load BIOS default, make sure the onboard audio function is enabled in BIOS
1.3.2 Re-install a new clear OS to test again
1.4 No output or input from the rear panel
1.4.1 Adjust the settings in Audio control panel
1.4.2 Update the Audio driver
1.4.3 Change the Audio device, like MIC, earphone, speaker
1.5 No output or input from the front panel
1.5.1 Please check if there is any output/ input from the rear panel, if not, please do some
troubleshooting as the step 1.4
1.5.2 Change to [AC97] mode in BIOS if the front panel module is AC97
1.5.3 Adjust the settings in Audio control panel
1.5.4 Check if the front panel is connected correctly
1.5.5 Change another chassis front panel connector for a try
2. Abnormal sound
2.1 Sound is low
2.1.1 Adjust the settings in Audio control panel
2.1.2 Close some sound resource which is not used for a while, such as SPDI/F, MIC
2.1.3 Update the audio driver
2.1.4 Change the Audio device, like MIC, earphone, speaker
2.2 With noise
2.2.1 If caused by the magnetic field, keep it far away to have a test
2.2.2 Adjust the settings in Audio control panel
2.2.3 Close some sound resource which is not used for a while, such as SPDI/F, MIC
2.2.4 Update the audio driver
2.2.5 Change the Audio device, like MIC, earphone, speaker
20 Oct 2010   #144
ipodtouchme
nope its just the white noise only even i play music and games....
20 Oct 2010   #145
brianzion
*quote from post above*
OS firstly
20 Oct 2010   #146
ipodtouchme
Audio is abnormal
OS firstly
2. Abnormal sound
2.1 Sound is low
2.2 With noise
where can i get "MICROSOFT UAA Function Driver for High Definition Audio"?
this looks hard to follow
20 Oct 2010   #147
brianzion
Microsoft UAA Bus Driver for High Definition Audio: Free Download
Microsoft UAA Bus Driver for High Definition Audio Driver for Windows NT / Windows 2K / Windows XP Free Download - Softpedia
is this the patch? the web site recommend?
http://support.microsoft.com/kb/888111
20 Oct 2010   #148
ipodtouchme
dont know ? im trying to download it but its not poping up so i can download
20 Oct 2010   #149
brianzion
20 Oct 2010   #150
brianzion
Quote   Quote: Originally Posted by ipodtouchme View Post
just having a read myself for you
Audio on computer displays it's working but no audio is coming through
I recently encountered this problem I was on windows 10 but I decided to do a fresh install mind having to put over like 6,000 files on to a uploading website cause I do youtube, editing etc whatever and so it first started out as like when I would max out the speakers it would do like a...
Laptop speakers working, but headphone jack not working only on Window
Hi, I have a dual boot of Fedora and Windows, and when I boot into Fedora, my headphones work fine. When I boot into Windows 7 64bit, my headphones don't work. My laptop speakers work fine however, and I tried re-installing drivers. I made sure that my headphones are the default playback...
Realtek audio, Gigabyte mobo: strange-sounding audio, mic not working
I have a self-assembled desktop PC - full specs in the signature below, but in short, it has an AMD Phenom II X6 1090T processor on a Gigabyte GA-970A-DS3P mainboard, which uses a Realtek Azalia ALC887 on-board sound system. I have no loudspeakers and listen to the computer sound exclusively...
Asus onboard audio no longer working since enabling front panel audio.
My audio rear outs used to work, but even so, i was primarily using hdmi out from my video card. I was also diagnosing BSODs at the time and sent my mobo back to asus for an rma. When it got back, I placed it in a different case and attached the font panel audio. Due to a new living...
Onboard audio not working and audio drivers won't install
Hello everyone, I'm having a problem using my motherboardís onboard HD audio instead of my video cardís audio, so without further ado here is the situation; I have an Asus maximus iii gene motherboard which has a SupremeFX X-Fi built-in sound card (this is a very nice card provided you can...
