Windows 7: Window 7 audio not working please help !!
19 Oct 2010   #41
brianzion
i have compressed the realtek software for you but the file is to big to post
19 Oct 2010   #42
brianzion
Quote   Quote: Originally Posted by ipodtouchme View Post
Quote   Quote: Originally Posted by brianzion View Post
right. click on file top left save as text file and then compress to zip file (when the file is downloaded right click on it and click on send to compressed zip folder and post zip file.)
DOne so what u going to do with that ?
just checking the specs for you
19 Oct 2010   #43
ipodtouchme
Window 7 Ultimate 64bit
alright !! how do i rep you up ? Lol
give me link i can download it. since its realtek do i have to install realtek hd audio driver ?
19 Oct 2010   #44
brianzion
the icon in the middle of the cross and report post at the top right of post but we are not done yet
19 Oct 2010   #45
brianzion
have you checked the bios for the settings for audio ?
19 Oct 2010   #46
ipodtouchme
Lol just wanted to rep you up since your helping me
19 Oct 2010   #47
ipodtouchme
yeah i have check the bios setting i dont remember what is but i didnt change anything
if i did, i would already load default
19 Oct 2010   #48
brianzion
19 Oct 2010   #49
brianzion
you have to check to see if the audio is enabled most bios are the same to check this it should be in advanced settings in bios
19 Oct 2010   #50
ipodtouchme
alright let me restart comp and check it Be right back
Audio on computer displays it's working but no audio is coming through
I recently encountered this problem I was on windows 10 but I decided to do a fresh install mind having to put over like 6,000 files on to a uploading website cause I do youtube, editing etc whatever and so it first started out as like when I would max out the speakers it would do like a...
Laptop speakers working, but headphone jack not working only on Window
Hi, I have a dual boot of Fedora and Windows, and when I boot into Fedora, my headphones work fine. When I boot into Windows 7 64bit, my headphones don't work. My laptop speakers work fine however, and I tried re-installing drivers. I made sure that my headphones are the default playback...
Realtek audio, Gigabyte mobo: strange-sounding audio, mic not working
I have a self-assembled desktop PC - full specs in the signature below, but in short, it has an AMD Phenom II X6 1090T processor on a Gigabyte GA-970A-DS3P mainboard, which uses a Realtek Azalia ALC887 on-board sound system. I have no loudspeakers and listen to the computer sound exclusively...
Asus onboard audio no longer working since enabling front panel audio.
My audio rear outs used to work, but even so, i was primarily using hdmi out from my video card. I was also diagnosing BSODs at the time and sent my mobo back to asus for an rma. When it got back, I placed it in a different case and attached the font panel audio. Due to a new living...
Onboard audio not working and audio drivers won't install
Hello everyone, I'm having a problem using my motherboardís onboard HD audio instead of my video cardís audio, so without further ado here is the situation; I have an Asus maximus iii gene motherboard which has a SupremeFX X-Fi built-in sound card (this is a very nice card provided you can...
