#191
I can get theses
Creative Sound Blaster X-Fi Titanium PCIe [SBXFI-TITAN-CO] - $109.00 : PC Case Gear 106$
or
ASUS Xonar DX PCI Express 7.1 Audio Card - HotHardware 91$
or
ASUSTeK Computer Inc. 91$
so which one ?
just be careful with it and dont touch the boards make sure you ground yourself when you have the case open or buy a antistatic wrist band and use that when you fiddle in the pc read the instructions with the card but most cards you put in after you boot up windows will install the drivers but read the instructions
Protect all your computer equipment from damage due to electrical static discharges with this high quality anti static wrist strap. With a 1.8 meter long grounding wire, this cable is perfect for computer enthusiasts and field technicians that need a portable and economical static protection solution.
okey dokey let me no if you get stuck the forums are always here you have my email keep the receipt
some advice in another thread Creative Sound Cards.
