critical battery sound volume level?
  1. Posts : 14
    win 7 ultimate 64
    i have critical battery sound set on my laptop to turn on at 10% and then 7% and shut the computer down at 5% if i do not do anything about it. problem is, sometimes i have the volume real low or off and dont hear it. is it possible (in windows, not an external program, although i will look to externals if not) to set the volume at a standard when the critical alarm goes off? in example, my laptop is at volume 2, then it hits critical level of 10% battery left, i want the computer to automatically bump up the volume to 20 or 30 depending on what i choose. kinda nit picky i know, but hell i know it can be done, if not in windows surely someone can recommend a good program. thanks to everyone who takes time to read and reply. -n00b
    You would need a special program just for that function, that whenever it needs to report the battery condition it would also raise the volume level. I've never seen anything like that. Have you tried doing a google search?
  3. Posts : 1,849
    Windows 7 x86/x64, Server 2008r2, Web Server 2008
    You may be able to set something in task scheduler:
    Condition = low power
    action = Volume = %75
    Action = play sound, or display on screen message
    Action = Sound normal volume
    Im not sure if you can set a condition like that but it could work.
  4. Posts : 14
    win 7 ultimate 64
    ok ill keep doin my homework on it. thanks everyone for your time!
  5. Posts : 2,259
    W7 Professional x64
    I believe that there is a program that instead of a tray notification, which I miss all the time, it gives you a large pop up. **searches the internet**
