Windows 7: Sound Bar Problem
22 Oct 2010   #1
ipyro24
Windows 7 32 bit
Sound Bar Problem
Every time windows makes a sound (not the internet or windows media player) the sound bar comes up. I don't know the proper name for what comes up but its the volume bar like on a TV. The same bar comes up when I hit the "vol. +" button.
It is starting to get annoying because it is always popping up.
22 Oct 2010   #2
Lemur
Do you have volume buttons on the monitor?
Did you recently install any applications that use sound?
Think back to when this first happened. Anything installed?
I guess you could scan for malware with malwarebytes.
22 Oct 2010   #3
ipyro24
Windows 7 32 bit
I just did a clean install on my brand new laptop, its the same bar that comes up when I use the vol. buttons. It started after I installed the software / driver that enables the buttons. I also noticed that the screne brightness buttons don't work, they bring up a brightness bar but cant lower it. The only way to adjust brightness is through the Mobility center.
Thanks in advance for any advice!
22 Oct 2010   #4
Lemur
What if Mobility Center is your problem?
22 Oct 2010   #5
ipyro24
Windows 7 32 bit
How can I diagnos which app is the culprit?
22 Oct 2010   #6
Aphelion
Windows 7 Home Premium
Does Mobility Center have a graphic interface?
If so, there may be an option to stop the volume bar from being visible.
If it's not mobility center it's most likely a small application installed by the button drivers.
It's either a "service" or is part of the run/startup section of the registry, you can run msconfig and check the "startup" and "service" tabs.
Ap
 Sound Bar Problem
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Sound problem perrsists even after new sound card
As some of you might remember, a few weeks ago I had a problem with sound after I built a new PC and kept my old Win 7 installation using sysprep: https://www.sevenforums.com/sound-audio/280175-onboard-sound-issue-new-pc-build-2.html#post2308990. The problem was that the volume levels were off, and...
Sound Problem
I have tried to play mpegs and Avi files on Nero Showtime (Nero 7 ) and also on Divx 8, Realplayer and Quicktime but I get no sound. I do get sound on Win Media Player only. I installed Klite codec pack for Win 7 64bit. Do I have to install the 32bit codec pack for the 32bit programs to...
Sound problem - need to 'scan for hardware changes' to get sound
Hi everybody I have a fairly strange problem with my Laptop. It came originally with Vista and a while ago I updated to Windows 7 32bit Home Premium. Since then I don't have any sound after booting the Laptop. By chance I found out that when I go into the device manager, right click on the sound...
Hardware & Devices
Windows Media Player Problem - Sound/skipping problem.
Oh look, another windows media player problem, lol. Well, it's something really weird, at first i thought it was just my computer being all slow or the file was messed up, No matter what movie or format i play it makes this weird screeching noise. It also lags pretty bad. I tried the scans, i did...
Music, Pictures & Video
