Windows 7: Please help!! Sound card disortion
24 Oct 2010   #1
heleonardman
Please help!! Sound card disortion need fixed ASAP VERY IMPORTANT
Okay, so today I went by Best Buy to get another USB sound card for my laptop to cue music to my headphones in VDJ. It installed the drivers, and told me to reboot. So, I did. When I played a few songs, they all sound extremely distorted and just horrible. every sound now sounds extremely bad from both my internal sound card and my USB one. I have a dance this friday that I am DJing for and I need this fixed ASAP!! Please help!!
24 Oct 2010   #2
jamtso
windows 7
You should be using only one sound card. usually when you plug in a external the one on the mother board should shut down,go into device manager and see if there is a conflict. If you're using Xp it's the sound video and game controllers see if the devices are working properly. What OS are you using?and what laptop do you have? give us the brand name and the model. and the kind of usb sound card? the more info the better.
24 Oct 2010   #3
heleonardman
Quote   Quote: Originally Posted by jamtso View Post
Yes, I fixed it by re-installing all drivers and screaming at it. it all works now. Thanks!
Creative Sound Blaster Audigy FX Sound Card, no playback/recording
Hi, I recently purchased the Creative Sound Blaster Audigy FX and am having problems getting it to actually play any audio or record any sound. I've browsed other threads with similar issues on this board and as such have disabled my motherboards onboard audio in my BIOS settings, have...
Distortion sound using onboard realtek sound card on windows 7ultimate
Hello,i recently upgrade my system from xp to windows7,i use the same realtek driver and get distortions!I try severall drivers,disable all enhancements/levels on speakers properties with no result(2.1speakers-),i configure them in stereo mode,i reduce the default format to 44100 16bits(cd...
factory sound card VS SoundBlaster USB sound card
hello in my present setup i have a factory soundcard thats installed in my intel atom mini pc and i have a usb soundblaster laying around.. my question is it worth to swapp in the usb sound card or its not much of a difference using the built in sound card my PC Cheap Intel Atom Mini Pc Hi10c...
BSODs playing GTA IV - No Sound (Sound Card) & Laggy Video!
Been having major issues playing GTA IV. First, the sound kept getting cut during gaming. When I exited the game, there was no sound in Windows either. I had to reboot to get sound but after a couple of minutes, the sound cut off again and I wasn't even gaming then. Video playback became really...
BSOD Help and Support
FPS drop because of sound card / sound card drivers?
I've recently upgraded my os to windows 7, and noticed a significant fps drop in all games I've installed. The problem seems to come from the sound card. I've disabled it in device manager and I gained a steady 15-20 more in most of the applications. Any idea what to do? Is it a driver issue or...
Gaming
