you need one of these if you have a usb socket
ZALMAN 5.1Ch USB Sound Card ZM-RSSC Sound card - 96 kHz - 24-bit
Yep, only a 3.5mm jack pin (well, the size of any normal set of headphones, I don't know wether it's 3.5 but I suppose it is, sorry again I don't know the first thing about sound...)
Ok, thanks a lot, so I've just got to buy an external sound card, install it and that's it? And should I use my HDMI connection if possible, or just stick to the normal jack pin?
Anyway, thanks a lot for your help!
And yes of course I've got USB^^
you need a USB SOCKET to use the external sound card
http://www.zalman.com/ENG/product/Pr...ad.asp?Idx=348
I've got several USB sockets, don't worry^^ And is there any risk of the card not working with my computer, or should any external sound card do the job?
i think it will ok read the zalman link its designed for notebooks ::: Zalman, leading the world of Quiet Computing Solutions :::
Yep, I should be getting my speakers & sound card next week, so I'll keep you posted :)
