Windows 7: How to increase max volume and decrease minimum volume
03 Nov 2010   #11
ThumperSD
Quote   Quote: Originally Posted by xarden View Post
Quote   Quote: Originally Posted by ThumperSD View Post
I would rather increase the volume in windows than on the monitors themselves. Each monitor has it's own knob so it's not very practical to balance them every time I want to increase/decrease volume.
You shouldnt need to set it everytime. Just the once to calibrate the max level you want.
The controlling of the volume when it needs to be controlled is through Windows.
Think of it as a hall, or theatre. The monitors are the front of house speakers, which have been set only once, and the only other times they get touched is to get powered on/off. And your PC as the sounddesk, which all applications, guitars, singers are controlled by.
I understand but if I calibrate it to the max level I desire, my 0% volume will be louder, which will not fix my problem. My 0% volume already has a quiet sound. I want it to be muted when it's at 0%.
03 Nov 2010   #12
ThumperSD
Quote   Quote: Originally Posted by zekramcross View Post
Hmm.. so your using a home audio system...
Do you have an audio reciever with those speakers if so try messing with the knob on that if you don't have one then, I don't know what to say at this point except going with xarden's plan and see if that works.
Yea receiver is not needed. It's not really a home audio system, more of a music producer's studio monitors. It's used to edit and find flaws in music and stuff.
03 Nov 2010   #13
xarden
Windows 7 Enterprise
I believe that would have something to do with Windows communicating to the sound card itself.
Likely a driver issue, which is outside the scope of my expertise.
04 Nov 2010   #14
ThumperSD
I know it's not a driver issue. I have connected other speakers to this exact setup just weeks ago with no problem. Max volume was higher than I wanted and minimum volume has NO sound (which is what I want).
I guess I'll just have to adjust the knob in the back of my studio monitors then.
04 Nov 2010   #15
Aphelion
Windows 7 Home Premium
I dont have regular speakers. I have BX5a studio monitors. I am using a dual 1/4 to 1/8 (3.5mm) cable connected to my Asus Xonar DX. Drivers are up to date.
It sounds like you have "Loudness Equalization" active.. except, I'm not sure if the Xonar drivers integrate with the Win Seven's audio system in such a way that you have any of the Windows 7 Enhancements.
Loudness Equalization is another name for compression & level limiting.
The Xonar is Win-7's default audio device, right?
Right click on the Microsoft Speaker icon and select "Playback Devices", single left click on your default audio device... "Speakers" ? Then select the "Properties" button.
There should be an Enhancements tab, select it and scroll down the list of Enhancements, (first select "immediate mode) see if you have Loudeness Equalization enabled.
Or if it's even there.. I don't know if this is even applicable with the Xonar card.
If not, maybe there's something similar in the Xonar's audio control panel.
Ap
04 Nov 2010   #16
ThumperSD
^ Actually I never disabled the onboard sound when I installed my Xonar. I never found the need to however since my Xonar has not given any problems so far. But I will look into what you mentioned when I get home.
Realtek Audio volume slider bar won't increase volume. No sound at al
I recently lost all sound on my desktop computer. I have done troubleshooting and it indicates my Realtek Audio is working. It also said it detected low volume and fixed it. However, still no sound. I try to slide the volume bar to 100% but it automatically slides back to 0%. I have updated...
Encrypted Volume Check: Volume Info on \\?\Volume{X}Can't read
Encrypted Volume Check: Volume Info on \\?\Volume{X}Can Not Read Found this in my Event Viewer on each start/restart. I don't have any Volumes that I have encrypted. Is this malware? I've run everything prior to noticing including Windows Offline Defender. Not sure if this is even the...
General Discussion
How to Increase and Decrease Volume through registry in windows 7
:D Help i need this thank u:shock:
The overall loudness/volume decrease when Windows is re-install!
The topic says it all. I thought it was just me but i asked a few of my friends and they noticed the same thing. Whenever i re-do my windows,the overall volume is greatly decreased and i mean with master volume of the windows maxed out. After a few days or weeks the volume gets back up where you...
Music plays even at minimum volume
Hey guys, I have a small issue with my volume. When I control the volume using the sound icon in the system tray (aka via my keyboard's volume control buttons), it works fine except when I bring the volume all the way down. Sound still plays at zero volume, and it only stops playing when I...
