error 1068?? please help me, no audio.
  1. Posts : 38
    Windows 7 ultimate 32 bit
    hi, my comp is having some audio problems and i need help.
    -windows 7 ultimate 32 bit-
    it says i have no audio playback device installed?
    One or more audio service isn't running?
    Both the windows audio and the windows audio end point builder services must be running for audio to work correctly. Atleast one of these services isn't running?
    I dont know what to do.?
    it says i dont have a playback device installed? no devices displayed when i open playback devices.? how do i get a device or install a driver to fix the problem.
    in services both windows audio and windows audio endpoint arent started.
    -when i turn on windows audio i get error 1068: the dependency service or group
    failed to start.
    -when i turn on windows audio endpoint builder i get error 1084: this service cannont be started in safe mode
    sound doesnt work no audio at all.
    ps: i dont have a restore point. i can only boot up in safe mode with networking.
  2. Posts : 28,845
    Win 8 Release candidate 8400
    failed to start.
    Are you booting into safe mode for a reason? The service may or may not start there.
    Other issue preventing a normal boot?
    Ken
  3. Posts : 5,056
    If you can boot into windows normally, do the following:
    1) Make sure the following services are running and set to automatic startup- Multimedia class scheduler, Remote Procedure call, Windows audio endpoint builder, Plug and Play.
    2) In device manager, look for a yellow exclamation mark under the category "Sound, video and game controllers". Do you have the driver cd for the mobo? If yes, install the audio driver, then go online to update to the latest version.
  4. Posts : 38
    failed to start.
    Ken
    its preventing me to boot normal. i get the bsod screen then it restarts thats y i gatta start in safe mode?
    Also (The window security center service is turned off)
  5. Posts : 5,056
    Download and run malwarebytes. Let it clean what it wants.
  6. Posts : 11,840
    64-bit Windows 8.1 Pro
    Blue Screen of Death (BSOD) Posting Instructions
    Follow these directions and we'll try to sort it out for you..
  7. Posts : 38
    failed to start.
    Ken
    i get bsod when starting windows normal boot up.
    bsod:
    0x00000116
  8. Posts : 8,383
    levi655 said:
    Ken
    bsod:
    0x00000116
    Follow Tews suggestion :)
  9. Posts : 38
    i followed the intructions but idk what to do on this part
    (3. Run a System Health Report -
    START | type perfmon /report - a viewer will appear | Save as an HTML file (default file extension)
    how to make html file?
    i only have (Performance Monitor) when i type in perfmon /report
    4. Windows Explorer will open to your Documents folder. Zip up the entire Windows_NT6_BSOD_jcgriff2 folder & the PERFMON HTML file and attach the zip file to your post.)
    how to do this alos. thanks
  10. Posts : 8
    Bill2 is right
    Bill2 is right.
