Windows 7: Sound Issue
12 Nov 2010   #1
mhar6988
Windows 7 64-bit
Sound Issue
I custom built a computer and when I connect my hp w1907 monitor to it I cannot get any sound from the built in speakers. I checked all of the settings and they looked to me like they were correct. Can someone help me on this issue? Thanks
12 Nov 2010   #2
whs
Microsoft MVP
Can you get sound if you attach e.g. a headset?
12 Nov 2010   #3
linnemeyerhere
Windows 7 Ultimate 64
mhar6988,
Welcome to SF. A complete list of your equipment would be helpful.
13 Nov 2010   #4
mhar6988
Windows 7 64-bit
I don't know. My friend said I need to get a set of them but I don't want to keep spending money on little odd and end things but I will say my DVD player will play a DVD but no sound will come out so I think if I can get sound there it will probably be a start of finding out the problem. My friend is a computer Tech and he said it was a configuration problem because my computer is a custom build and my monitor is an hp and has built in speakers. Let me know what you think. Two heads are better than one...LOL
13 Nov 2010   #5
whs
Microsoft MVP
Can't you borrow a headset for a couple of hours or don't you have one lying around. Even the little earplug types that come with a lot of little machines - as long as they have a 3.5mm plug. That would be the easiest test to see whether we are talking about a hardware or a software problem.
Your friend could have a point too. It could be a driver problem with the HP monitor. Did you look on the HP website whether there was a particular driver required for the monitor.
Another place to look: right click on the speaker icon next to the clock (bottom right) and go to "Playback Devices". See whether your monitor speakers are set as "Default Device" (it would show a checkmark in a green circle). If you right click on any shown device that is not greyed out, you can set that as default. If there are several possible, change them around. Maybe you find the one that fits.
 Sound Issue
Reoccurring low sound issue affecting two sound cards
I had this issue before, all of a sudden the sound coming from my computer gets really quiet even though everything is maxed out. Before, it seemed to have been triggered when I moved my computer from one room to another. I wasn't able to move it back right away but when I did it was still...
RealTek OnBoard Sound Issue - No Sound
Hello everyone, My audio has seem to quit on me. I updated to the newest drivers for my mobo (biostar A870U3) from their download page and now I get no sound whatsoever from my speakers. I have tried uninstalling all of the sound devices from the device manager and letting windows reinstall...
Sound Blaster X-Fi Titanium Sound card issue
I have put the sound card into my computer and made sure that I've hooked up everything correctly, but I have ran into a problem with it. When I ran the download "Product Identification Module Update" from the Creative website, it's telling me that I don't have the right OS, and tells me to update...
Sound issue (Conexant sound driver)
Ok, first of all, i'm not sure how to properly explain this, because it's confusing, but i'll try my best and if any more information is needed please let me know! So, I bought this packard bell laptop preinstalled with windows 7 from pc world in September. And for as long as I can remember,...
No Sound Issue
Hi Fellas, I've just recently installed Windows 7 Ultimate - all went smooth besides the fact I cannot get any sound to work, from my Logitech X530's or my Plantronics Gaming Headset. I am using onboard sound and have updated the mobo driver in accordance with the Win 7 32 bit Realtek...
