Switching Front stereo Left and Right Speakers
  1. Posts : 33
    Windows 7 Home Premium x 64
    My cables for my front speakers can only go in reverse as the cable lengths!
    Is there any software to switch L/R R/L :).
    I have realtek HD Audio.
    If the connectors for the speakers are standard connectors, get some extension cables.
  3. Posts : 33
    The front right speaker is the problem. It uses a 15 pin connector to the sub. (vga like) the other is just standard.
    If there is an extension cable ill get one! i cant find what i need? any links will help. I have the Green (stereo), Orange (center and sub), and black (rear stereo) connectors for my pc. An extension for that will work!.
  4. Posts : 571
    Some sound card drivers actually have an option to swap the left and right channels in their Control Panel applet.
    I think RealTek does (or used to).
  5. Posts : 33
    Ive looked round all the software and there is no reverse stereo of calibration. i cant believe realtek have left something so simple out .
    I guess ill just buy 3 seperate jack cable extensions
