Wave volume control...
I can bearly hear sound from my computer's speakers even with the main volume
set to maximum. I had a similar problem in Windows XP and fix it by
increasing the wave volume in the volume control. I can't find the wave
volume (just the main volume) in Windows 7 ultimate. Where is it?
If I can increase the wave volume,
then that will fix my problem.
Thank you. And yes, everything is plugged in
and powered up. Thank you.
