Wave volume control...
  1. Posts : 3
    windows 7 X86, 32 bit, ultimate
    I can bearly hear sound from my computer's speakers even with the main volume
    set to maximum. I had a similar problem in Windows XP and fix it by
    increasing the wave volume in the volume control. I can't find the wave
    volume (just the main volume) in Windows 7 ultimate. Where is it?
    If I can increase the wave volume,
    then that will fix my problem.
    Thank you. And yes, everything is plugged in
    and powered up. Thank you.
  2. Posts : 8,398
    ultimate 64 sp1
    the simple way is to click on the speaker icon next to the clock.
    or control panel >> hardware and sound >> sound >> adjust system volume
    depending on your sound card (or chip), you may have an extra set of controls somewhere in your start-menu.
    do you know what sound card you have? and are you sure you have the latest drivers downloaded from the manufacturer. sometimes windows update can help find drivers.
    Attached Thumbnails Attached Thumbnails Wave volume control...-sys.png   Wave volume control...-contr.png   Wave volume control...-xfi.png
  3. Posts : 3
    @mickey megabyte
    thank u for ur honest and straight reply...
    and also for the screen shot...
    but , i tried all these before i do the post...
    all volumes, in all speakers is full!....
    everything is full....
    i have a inbuilt sound card which is Realtek audio!..dont know versions and all..
    all drivers are properly installed, and checked...
    all volume in all panels is set high...
    but still the sound is 10% of total volume.....
    the same problem was happening in Windows XP...and the wave volume would have dropped to 10% , i would correct it instantly as the "WAVE " bar was there in main volume control only....
    What is "WAVE" volume bar in windows 7, and where it is a big question!...
    plez answer fast!
  4. Posts : 8,398
    ultimate 64 sp1
    i'm sorry i don't know - i've never seen a wave volume control in 7, only xp.
    do you have realtek audio control panel?
  5. Posts : 3
    yes...its realtek HD audio manager!
  6. Posts : 9,582
    Windows 8.1 Pro RTM x64
    Do you have Loudness Equalization enabled?
