Windows 7: Realtek HD Audio No Rear Sound
10 Jun 2009   #11
jebuchanan
Windows 7 Ultimate x64 (Retail)
The one from Realtek is a small update to what Asus has: 6.0.1.5859
I use an Asus P5K mobo w 7.1 surround.
10 Jun 2009   #12
shaheer92
Quote   Quote: Originally Posted by jfar View Post
Try the one you are downloading at the moment and we will see what happens.
Ok, downloaded and installed. I got the Audio Manager back, and I set it up again to QUADRAPHONIC.
I pressed the four speakers one by one, and heard a sound effect from each of them, BUT they were BUZZING. I out my headphones on, and the buzzing noise was even there.
I tried playing a song again, and again i couldn't hear anything form the rear speakers, and the front speakers had this weird annoying buzzing sound.
Its back to the original problem, only with an additional BUZZ problem too.
10 Jun 2009   #13
jfar
Vista Ult64, Win7600
Turn off your system Shut Down and turn it back on, not restart.
10 Jun 2009   #14
shaheer92
I shut it down and turned it back on, but still no luck...
10 Jun 2009   #15
jfar
Quote   Quote: Originally Posted by shaheer92 View Post
Ok it was just an idea I was having at the time, ok did you install everything for your motherboard when you went to the Asus site.?
10 Jun 2009   #16
shaheer92
Well, not everything. I just installed the BIOS update, it fixed my problem that it showed my CPU temperature as 100 C /212 F all the time. And I installed the LAN Update.
10 Jun 2009   #17
jfar
Nice one, keep doing them.
10 Jun 2009   #18
shaheer92
Even the Audio update?
10 Jun 2009   #19
shaheer92
I didn't install the audio update from ASUS yet, but good news is that my rear speakers are working...dunno what I did, lol.
But the buzzing's still there
10 Jun 2009   #20
shaheer92
I thought if i'll install the audio driver on ASUS site it'll remove the buzzing and the rear speaker sound will stay.
the buzz is gone, and so is the rear sound. I tried fixing it, doing the same stuff I did before to make it work, but nothing happened.
I'm really going crazy...its so annoying...
Realtek ALC889 audio, audio fine on S/PDIF, nothing from rear output
I'm having a strange problem in my HTPC. Audio is coming perfectly fine out from the S/PDIF coaxial output, and it's normally connected only that way to the receiver, but now for other reasons I also need to connect it using a 3.5 mm to a small mixer. So in the sound manager I changed the output to...
Realtek HDMI+NVIDIA = no sound+frezze screen using pc rear audio jack
Hi every one i am new at this i might carry on please forgive me if that happens. i am having this Realtek HDMI+NVIDIA =No Sound issue + if i connect back to my rear audio jack with my speakers its fine to listen music but it freeze the screen during game play and gives out a loud buzz sound than...
Realtek HD Audio Manager ''Mute Rear Speakers'' HELP
Hey, For quite a while now i've been using a pair of USB Speakers. I had it set so my games came out my speakers and my Team speak Voice chat came through my headset. I recently decided to swap back to my Creative speakers, but now i have an issue. When i plug my speakers and headphones in...
Realtek HD Audio Non Working Rear Speakers
Hello Everyone , I recently searching in forums to get solved my problem , but no one fix that issue . I Read many threads so i need the fix because i'm sick to see another posts from fools that they don't know anything about software's or hardware's. So My Problem Is : Yesterday i format...
Realtek AC'97, No rear sound
Hi all, my problem is as follows: Currently running Windows 7 Professional 64, with an Asus A8N SLI Premium, which features the Realtek ALC850 (AC'97) audio chipset. Back when I had XP Pro, the 5.1 speakers I have worked fine. After upgrading, the rear speakers refuse to work. Checking the...
