The one from Realtek is a small update to what Asus has: 6.0.1.5859
I use an Asus P5K mobo w 7.1 surround.
Ok, downloaded and installed. I got the Audio Manager back, and I set it up again to QUADRAPHONIC.
I pressed the four speakers one by one, and heard a sound effect from each of them, BUT they were BUZZING. I out my headphones on, and the buzzing noise was even there.
I tried playing a song again, and again i couldn't hear anything form the rear speakers, and the front speakers had this weird annoying buzzing sound.
Its back to the original problem, only with an additional BUZZ problem too.
Turn off your system Shut Down and turn it back on, not restart.
I shut it down and turned it back on, but still no luck...
I didn't install the audio update from ASUS yet, but good news is that my rear speakers are working...dunno what I did, lol.
But the buzzing's still there
I thought if i'll install the audio driver on ASUS site it'll remove the buzzing and the rear speaker sound will stay.
the buzz is gone, and so is the rear sound. I tried fixing it, doing the same stuff I did before to make it work, but nothing happened.
I'm really going crazy...its so annoying...
