can't listen to onlline radio or live streaming
  1. Posts : 6
    Windows 7 64bit
    Hello guys. It is my first post and hope to find some help with my laptop sound problem. The last 3 days i can't listen to live streaming such as online radio or online tv etc.. I try to install again the google chrome, i install again the wmp firefox plugin on my chrome, i install the java again but nothing. What could be the issue for this sound problem? Thank you guys for any help.
  2. Posts : 1,939
    Windows 7 Ultimate 64 bit Steve Ballmer Signature Edition
    Welcome to SevenForums mikekyrou!
    Do you have sounds anywhere???
  3. Posts : 6
    Windows 7 64bit
    yes, everything else works fine such as youtube and music on my laptop but not on the online radio stations... :s
  4. Posts : 6
    Windows 7 64bit
    no one can help me??
  5. Posts : 1,939
    First thing to consider... many of these radio stations use Flash, so make sure you have the latest version of Adobe Flash Player.
    Are you using the 64 bit version of IE or??? If yes, try the 32 bit version... there are some "issues" with Flash and IE64.
    You dont have any other apps open at the time monopolizing the speakers do you?
  6. Posts : 3,139
    Did you try pandora?
    Pandora does not use plug-ins and I want to see if it's a plug-in issue.
  7. Posts : 152
    Windows 7 Ultimate (32-bit)
    You could also give RadioSure a try. It works great and it's free.
  8. Posts : 17,545
    Windows 10 Pro x64 EN-GB
    Feel free to call me an idiot if you think I'm stupid offering so simple possible solution, but this could be one of those issues where theory of Occam's Razor apply.
    According to your problem description, only sounds you don't get are those of a browser. Have you checked that you are not accidentally muted your browser?
    Kari
  9. Posts : 6
    Windows 7 64bit
    i don't mute my browser because youtube is working fine... when i try to listen to live streaming it says ready but no sound...
  10. Posts : 8,383
    Pandora only works in the US
