5.1 Speaker System problem
  1. Posts : 2
    Windows 7 Home Premium 32bit
    Recently purchased Logitech X 530
    I have another set of these speakers on another computer with XP but I cannot get these speakers to work on Windows 7.
    Help on how to get these working for windows 7 is much appreciated, thanks in advance.
    The sub woofer works, just not the rear and center speakers
  2. Posts : 1,508
    Lion
    Please fill up your system specs to help you out.
    What is the sound card you use? A 5.1? Is the cables properly plugged in?
  3. Posts : 2
    NOOB QUESTION ALERT:
    Tell me where to find that and ill tell you :)
  4. Posts : 1,508
    Lion
    Goto UserCP and then Edit system spec
    Attached Thumbnails Attached Thumbnails 5.1 Speaker System problem-capture.png
  5. Posts : 4,466
    Windows 10 Education 64 bit
    On some motherboards (like mine) the audio jacks do double function. For instance on mine the line in is also the output for the rear speakers. I have to change the settings in my Realtek Control Panel for all my speakers to work. If you have already done that you may want to look at the sound settings in control panel. Something else I've noticed is I have to check the Speaker Fill option in the Realtek Control Panel or I only get stereo playback in Windows Media Player when I play any of my MP3 files.
