Switched to 7 Ultimate, problems with Audio driver
Previously I was on XP, I just installed Windows 7 Ultimate 32bit on an alternate internal drive. All the drivers installed themselves, including a graphics card that gave me issues and internet too. But there's no audio.
Troubleshooter says:
Problems found: Hardware changes might not have been detected, Detected (yellow exclamation mark appears beside that line of text)
Above that it says The troubleshooter made some changes to your system. Try attempting the task you were trying to do before.
I don't really know where to start, could someone tell me how to fix this?
Thank you.
edit:
Trying to place a mp3 into winamp results in a message:Bad DirectSound driver. Please install proper drivers or select another device config. Error 88780078
