Windows 7: No audio output device installed...Tried everything, need some help.
23 Dec 2010   #11
Brydom
Is the sound enabled in the BIOS? Also, did you install the Intel Motherboard chipset drivers? On many PC's the drivers must be installed BEFORE installing sound drivers or the sound drivers will not install.
Now....I checked the bios but found nothing about the realtek or multimedia or sound or anything like that. Where would I get the motherboard chipset drivers? I will do a search but don't really know what I am looking for...lol.
23 Dec 2010   #12
fireberd
In most systems there is an entry in the BIOS, to allow disabling it if an external sound card is used. It may be labeled "legacy audio". But, if there is none in your BIOS then it's always enabled.
The PC vendor should have Chipset Drivers, either listed as Intel Chipset Drivers or Motherboard Chipset Drivers. One of the main thing the chipset drivers do is define all the hardware devices on the motherboard, which includes the sound module (chip). You could also do a web search for "Mobile Intel(R) 965 Express Chipset" I found THIS at Intel, go through the instructions to verify it is for your system and then download and install it.
24 Dec 2010   #13
Brydom
Yeah, done that and nothing...lol. Going crazy here.
Might just go back to vista or just get a new laptop...lol.
No Audio Output Device Installed Error (Code 52 on my audio devices)
Hello there, I have an error in my Windows 7 with the audio, "No Audio Output Device Installed." I checked the playback & recording devices, but none are installed. I checked for hidden devices, but there wasn't any. So I opened the Device Manager, and checked the "Sound, video, and game...
No Audio Output Device is installed, HDMI Audio Out Works
No sound. Little speaker with the red 'x' appeared yesterday I have gone through the whole update drivers circus to no avail, my laptop can't detect that it has speakers built in so it doesn't bother finding a driver for them. This is where I am at: - Intel Display Audio is the only driver...
No Audio OUTPUT Device is installed
I upgraded my computer to Windows 7 Ultimate 32bit and im having problems installing the Realtek sound driver that's compatable with my computer. Every time i install it it says i dont have acces to memory location. I tried every solution on the internet but nothing worked. Please help me, im...
Alright, I give up. I've tried everything I can think of to fix this damned problem so now I'm left with no choice but to seek outside help. So, last night I updated windows after a minor leave of absence from doing so. and once everything was configured my computer started insisting I had no...
Realtek Audio: No Audio Output Device is Installed
Hello. Im having the dreadful "No Audio Output Device is Installed" problem on my realtek audio. It worked some months ago, but im in no position to do a roll back. Im sure the hardware is just fine, it works with Ubuntu. The computer is a Dell Vostro 430. My OS is win7 64bit. I tried...
