Windows 7: Problem Recording Streaming Audio
02 Jan 2011   #1
crunksmiley
Windows 7 Home Premium 32bit
I'm trying to Record Streaming Audio from a website, and none of the software I'm using is picking up the sound...The software picks up the mic, and line-in, but doesn't pick up the streaming audio, or anything that is being played on the computer.....I really need some help with this..I don't thinks it's the software...I have Nero Wave Editor, and a Sony Music Creator Software...Neither can pick up the streaming audio...
02 Jan 2011   #2
Aphelion
Set the default recording device to Stereo Mix if you have it.
Right click on the Microsoft Speaker icon in the task bar, select recording devices.
Right click anywhere in the window that opens and enable both "Show Disconnected" and "Show Disabled Devices" do you see "Stereo Mix" as an option? If so, select it and click the "Set Default" button.
There may be a Record Level luring under one of the tabs.
Ap
02 Jan 2011   #3
crunksmiley
Quote   Quote: Originally Posted by Aphelion View Post
Ap
I've done that...And When I set the recording software to record from Stereo Mix (Realtek AC-97 Audio) a error comes up saying it cant detect the sound device....This error come up for Nero Wave Editor and Audacity Recorder
02 Jan 2011   #4
whs
Microsoft MVP
I can do most amything with this MS program. Unfortunately the free version will cap the recording after 10 minutes. But maybe you like it enough to buy it. The quality - also for video recording - is excellent. The operation is typical Microsoft - more complicated than need be. But with a bit of practice, this should work.
BSOD During Streaming / Recording With OBS [Dark Souls 3]
Pretty self explanatory- my specs are on my profile and I'm including the zip file as per usual BSOD post. My computer runs the game fine and can even handle media on my second monitor during gaming. I've rarely had issues streaming / recording / watching stuff and gaming simultaneously - I've...
BSOD Help and Support
recording problem after installing dfx audio enhancer
Hi after installing dfx audio enhancer i can not record my voice with internal mic of laptop! I uninstalled dfx but problem exist! I can not restore windows and i just reinstalled windows caus if this problem! And after instakking dfx i get this problem again! I tried a lot of settings ... I'm...
Windows theme changes to basic while streaming-recording after 30min
Recently, I started streaming some games and recording it to disk. Windows has been flicking into Windows Basic theme after about 30min. How can I set windows to *not* change theme regardless of situation? I honestly couldn't care if windows claims my memory is low (my video card has 3GB and I have...
Themes and Styles
Recording audio
How can I record the audio portion of a YouTube video?
Recording audio
I tried to install Wavepad and it won't work with win7. Any suggestions for a freebie prog recorder that records free radio streams? This might be a deal breaker for me for moving back down to XP.
Twitter Facebook
