System Event - Changing sound makes a sound, how to mute it?
  1. Posts : 2
    Did my searching and couldn't find this one...
    When I modify the speaker volume using the "Volume Mixer" icon, it generates a sound. When I adjust using the "Speakers/Headphones" icon, it does not make a sound.
    I would like to mute the Windows 7 sound that happens when I adjust the sound, preferably without effecting the other system sounds? I can't find out which system 'event' it is that causes a sound to be generated when I modify the speaker volume. I'd like to mute it, i.e. no sound when I change the volume.
    thanks
  2. Posts : 17,796
    Maybe the solution is in this tutorial
    Sounds - Change
  3. Posts : 2
    well its not in that tutorial that I could see either...
    Using the "Sound" control panel, in the list of "Program Events" that you can assign a sound to, there is no entry for "Change Volume" which is what I would like to see...
  4. Posts : 1,996
    Windows 7 Home Premium 64 bit
    "System Sounds" adjustment is not sufficient?
  5. ie9
    Windows 7 Ultimate (SP1)
    Isn't it the 'default beep' sound?
