Windows 7: Creative Sound Blaster X-Fi Xtreme Audio
20 Jun 2009   #11
mavadosh
Windows 7 (7100) 32 Bit
Quote   Quote: Originally Posted by stormy13 View Post
Hope you realize that your Audigy 2 is a better card than the Xtreme Audio.
audigy2 is 6 years old, it doesnt even have working surround sound...
20 Jun 2009   #12
stormy13
Microsoft MVP
Win 7 Ultimate x64
So is the SB Live 24 bit, which is all the Xtreme Audio really is. Also why up until a little while ago the drivers for the Live 24 bit as well as the Audigy SE/DE/Value and the Xtreme Audio were a unified set, one driver package for all. All the Xtreme Audio is basically is a renamed SB Live 24 bit/Audigy SE/DE/Vlaue that gets to use some of the X-fi software (and doesn't even have game mode that the rest of the X-Fi's have).
As far as surround goes on that Audigy 2, it would probably work if you used these,
SB Audigy Series Support Pack 2.0 (04/17/2009) - Sound Blaster - Creative Labs
instead of the drivers from Creative. Also depends on what the source is, if it is a stereo source (pretty much any music), then the only way to get surround out of it is to enable CMSS3D, which the card supports.
21 Jun 2009   #13
mavadosh
interesting, what do ya think about the titanium? pcie
21 Jun 2009   #14
kpo6969
Agree completely, I've been using these for Vista and Win7 so I would believe you would see the same results as I have (no issues)
SB X-Fi Series Support Pack 2.0 (05/15/2009) - Sound Blaster - Creative Labs
21 Jun 2009   #15
stormy13
Microsoft MVP
Win 7 Ultimate x64
One small problem kpo, he has the Xtreme Audio and if he wanted to use the daniekl_k drivers he would have to use this one,
SB P17X Series Support Pack 1.6 (05/14/2009) - AudigySE/Value/LS_Live24bit_X-Fi XtremeAudio_SB5.1VX - Sound Blaster - Creative Labs
Oh and mavadosh, the Titanium is a much better card than the Xtreme Audio.
21 Jun 2009   #16
mavadosh
im using the official drivers from creative now they work with windows 7
i wanna get the titanium, but first TO TE JOB CENTOR!
Sound Blaster X-Fi Xtreme Audio: Speakers pop when I click some things
I put in a Creative Sound Blaster X-Fi Xtreme Audio (PCIe), installed the latest driver from Creative, found here: Creative Worldwide Support (1.04.0000, released 30th June, 2009), and it seems that whenever I click things that make noise (a good example being the volume slider in the system tray),...
Creative Sound Blaster X-Fi Xtreme Audio PCI - microphone problem
Hello there. Yesterday i've installed this sound card and everything works fine but no microphone. I can see it in control panel but it doesn't work. Mic is fine as i was using it before. I have Win 7 64bit. If you have any idea what can cause the issue please help, if nothing will work i will...
Creative's Sound Blaster X-Fi Xtreme Audio PCI Express
Hey mates, Today I bought and installed a new sound card. Creative's Sound Blaster X-Fi Xtreme Audio PCI Express. More information about the card can be found here: Creative Labs Online Store (Europe) | Sound Blaster | Buy Creative PCI Express X-Fi Xtreme Audio Anyway, this card is a...
Sound Blaster X-Fi Xtreme Audio 70SB104000001
Hi Im looking at Sound Blaster X-Fi Xtreme Audio 70SB104000001 i was wandering if anyone had any advice on this card. i can't see it on the seven compatiblity site but Creative has windows seven drivers to download. I was looking at the PCIe x 1 version as i have either a PCIe or PCI slot...
Sound Blaster X-Fi Xtreme Audio / Creative.com
Ok, so I read the stickied topic about the X-Fi Xtreme Audio driver, as I think this maybe a part of my computers less-than stable condition after recent Fresh Installs of Windows 7 Home Premium 64bit. I got 2 things... 1) When I install Drivers off my CD, I get a SpiRunE.dll error about a...
Twitter Facebook
