I've completely lost all playback in media player
  1. Posts : 6
    windows 7
    I hope there are windows media player diagnostic procedures.
    I've realized that all the media player playback functionality has been lost. I cannot even play sample wma files that comes with Windows. No videos in standalone player or Firefox/IE plugins work either.
    Media Center can play recorded TV.
    Zune software can play everything.
    And I checked with something called codec_sniper, most of the codecs in the system are OK.
    I can also use PowerDVD, even for BluRay playback.
    So it is the WMP that has the problem.
    I recently upgraded to 7100 x64. I had no problems on 7000 x64 with the same setup (same video drivers, same software, and btw "upgrade" was actually a reinstall).
    Are there any diagnostic procedures to find out what is wrong?
    ==== Ok, I solved the problem. The culprit was the Creative Driver...
  2. Posts : 50
    Win7 7201 x64
    I had a similar issue and found out it was the registry cleaner that caused the problems, have you used one?
  3. Posts : 6
    windows 7
    I don't remember doing a registry cleanup.
    I'm suspicious of three things:
    * Creative drivers
    * PowerDVD
    * Virtual XP Mode (installed WMP11 and iTunes in it)
    Is there a way to check "why" exactly it is not working?
    Btw the error message is:
    Windows Media Player cannot play the file. The Player might not support the file type or might not support the codec that was used to compress the file.
    To be sure I downloaded Media Player Classic, and it plays the files fine. So I have the codecs.
  4. Posts : 28,845
    Win 8 Release candidate 8400
    WMP
    * Creative drivers
    * PowerDVD
    You might be able to get more info by going into event viewer and see if there are error messages relating to WMP.
    Powerdvd probalby not causing this, virtual pc maybe but doubt it. could be creative drivers.
    Need more info
    Ken
  5. Posts : 6
    windows 7
    I could not find anything related to this in the event log.
    I think the only option for me is a clean windows reinstall at the moment.
  6. Posts : 28,845
    clean install
    Absolutely. Sorry I couldn't help more but a clean install will get rid of the problem.
    ken
  7. Posts : 31
    Windows 7, Windows Vista Ultimate, Ubuntu 9.04
    Did you try sfc /scannow ?
  8. Posts : 6
    windows 7
    C:\Windows\system32>sfc /scannow
    Beginning system scan. This process will take some time.
    Beginning verification phase of system scan.
    Verification 100% complete.
    Windows Resource Protection did not find any integrity violations.
    I'm waiting to find enough free time to do a reinstall. We should have a way to automate installation of Office, Drivers, Firefox, and all the other things.
  9. Posts : 28,845
    Actually when you re-install and get everything the way you want it do a backup and if you ever get in this position all you have to do is retore from taht back up and you will be set. I do thst sbout once a month just to keep the system clean
    ken
  10. Posts : 6
    windows 7
    Out of a hunch, I did a "rollback" of the creative driver. And after rebooting WMP started to work again!
    And I am still able to run Creative applications, and also SPDIF decoder has been fixed.
    Thanks to everyone who enabled me to be persistent.
