Windows 7: Microphone Problems PLEASE HELP!
19 Jun 2009   #1
teh cakinator
I have recently wiped my laptop and reinstalled with windows 7 and have been having problems with microphones ever since. Originally I was trying to fix the built in microphone, but now I have bought a brand new microphone.
The problem is the microphone is not picking up sound correctly. It only picks up sound dimly and I am unable to turn it up.
Please to help.
19 Jun 2009   #2
Johanster
Do you have, by any chance, paper stuffed inside the mike cavity?
-ontopic-
Try a driver update? Should work, or try running the program in a compatability mode. First things that come to mind.
19 Jun 2009   #3
teh cakinator
No sir, can't say I do sir.
20 Jun 2009   #4
Trev19
Same Issue,, they really need to fix it, cause alot of people are having this problem and no one seems to know how to fix it.. This is the only issue i am having with Windows 7.
20 Jun 2009   #5
teh cakinator
Quote   Quote: Originally Posted by Trev19 View Post
Ya, same here. I've seen a lot of people with it I was hoping someone would have found a cure by now
20 Jun 2009   #6
bjs53
Win 7, Home Premium
At the begining with 7100 RC 32 bit, microphone level was also very low. I have found that in Manage audio devices, recording, microphone, properties, levels - the default level is low. When I changed it to max it was OK. However I noticed one interestiing issue - In advanced tab you can check the option "allow applications to take exlusive control of this device", and then different application change the level in general, not only for that application. In my case Skype change the max 100% level to 70 %.
And even when I again set up 100% in audio configuration, Skype when I opened it make it lower - to the level appropiate for Skype but not for other application. When I unchecked in Skype an option "automatically adjust microphone settings" the level is kept on max. So you can unchceck the "allow applications to take exlusive control of this device" or keep proper level in application you use.
I hope it will solve your problem. It is solved in my case.
07 Feb 2010   #7
deborah53
Is the answer to the microphone glitch after intstalling Win-7 going to be a clean install of Win-7 or a clean install of my previous version of Vista? That's what a tech support guy told me on the phone today.
I think they just use that (clean install) when they don't know what the heck to do.
07 Feb 2010   #8
deborah53
Also; my Photoshop Elements 4.0 stopped working. does anyone have a workaround for the microphone problem or the PE 4.0 problem?
Microphone Quality Problems
Hi, I do gaming commentaries with my friend and I use Nvidia Shadowplay to record. Recently I got a Samson Meteor, reading really good reviews about it. It was great the first few weeks, but lately it has had worse and worse quality. I have tried using Audacity and that records my voice perfectly...
Headset microphone problems
Hi guys, been having a real problem lately. I bought a nice new corsair vengeance 1300 headset to go with my 600t case. However when i plug them in to the front jack the mic doesn't work. I know the mic works because i have tested in the back panel. Also when i plug them into the front panel i get...
Microphone problems.
So yesterday while i was playing on my PS3 while talking on skype, i decide to go to the bathroom with my headset on to brush my teeth, so lalala in i go and when i lowered my head my mic fell out of my headset and into a (semi deep) pool of water for about 2 seconds, ever since then to even hear a...
Microphone strength problems
Hello, i used to have an audigy 2 zs platinum pro, and with it there was a rack unit with a preamp for mic.. now.. it looks like it died on me last night, and so for the time being im stuck with the onboard audio.. the problem i have is that the onboard audio (Via 2020, software x-fi...
windows 7 microphone problems
hello everyone... the problem i am having is i am trying to record a small podcast using audacity, and it picks up my headset microphone no problem, the problems though is that audacity is also recording all system sounds too... i want to disable this so it only records my microphone i have...
Twitter Facebook
