Installed win 7 64 bit now sound wont work
Hi i have a sound blaster Audigy 24 bit advanced HD sound card. It worked fine while i had xp installed but i have now gone to 64bit windows 7 and be buggered if i can get it to work.
I can not seem to find the right driver for 64 bit. Have tried a couple of downloads but they just gave me an error. I have disabled the on board sound and this was infact done about 6 months ago. I rechecked the bios and it is still disabled. The error i am getting is
This device cannot find enough free resources that it can use. (Code 12)
If you want to use this device, you will need to disable one of the other devices on this system.
I have no other sound devices listed and onboard has been disabled....Hope someone can help.
As a side note it is NOT a sound blaster LIVE
