Realtek Audio not detecting analog inputs
Page 1 of 3 123 LastLast
  1. Posts : 6
    Windows 7 Home Premium 64 bit
    I have a Gigabyte GA-P55-UD3R that has had no problem for quite a long time using Windows 7 64 bit. Recently after a reboot, the integrated Realtek audio no longer detects any analog connection (tried with mic/speakers/headphones) in any of the jacks.
    I removed the current drivers using add / remove, rebooted, then installed the latest drivers from Gigabyte, then I tried Realtek directly, and finally the default Windows audio drivers. I also tried removing the drivers with driver sweeper, directly from device manager, etc. and installing a fresh set of drivers. Additionally, I disconnected the front audio jacks from the motherboard in case that was causing a problem. Windows detects the sound card and there appears to be no problems in device manager.
    I've gone through every available option in the Realtek sound control options, but I'm at a loss. I have a USB headset that works without a problem, but I can't get these darn analog speakers to work. Any advice? Before anyone says it, 'set default device' is grayed out as an option for the speakers.
  2. Posts : 1,996
    Provide a snippet of your Windows Volume mixer, Playback devices.
  3. Posts : 6
    10char
    Attached Thumbnails Attached Thumbnails Realtek Audio not detecting analog inputs-notpluggedin.jpg
  4. Posts : 1,996
    Do you have the speakers plugged into the back output on the motherboard?
  5. Posts : 6
    Correct...I've verified the speakers work via an MP3 player. I've tried them in every available jack (although green should be the correct one). I've also head phones and a mic which are also not detected.
  6. Posts : 6,879
    Win 7 Ultimate x64
    You tried setting the speakers as the default device instead of the digital?
  7. Posts : 6
    Correct; when the device is in the 'not plugged in' state the option to set default device is grayed out.
    I guess I can mark this resolved. I got tired of wrestling with this, chalked it up to hardware failure and bought a cheap soundblaster audigy. Thanks for the input guys.
  8. Posts : 2
    Windows 7 64 bit Home Premium
    WOW
    I am having this exact same problem in every way. Ive been going crazy and finally found this post. Is there anyone who has found a solution? Right now i can no longer use my headphone jack or my rear output. Working one minute, not working the next.
    Please help.
  9. Posts : 612
    MS Windows 7 Home Premium 64-bit SP1
    Please help.
    Dear Brandon Hill,
    Welcome! Are you ABSOLUTELY sure(sorry for the caps) that all the jacks are snugly and properly fitting into their respective slots! I mean ,no loose connections at all? I am asking because you are getting and losing the sound moment to moment! Connections, always check connections,my hardware engineer friend used to say!
    Regards,
    Sreedhav
  10. Posts : 612
    Dear Brandon Hill,
    I am posting my audio input to a microphone jack and can you provide a similar snippet? Mine was just diagnosed as "LOW AUDIO VOLUME" by the MS troubleshooter
    regards,
    Sreedhav
    Attached Thumbnails Attached Thumbnails Realtek Audio not detecting analog inputs-recording-audio_2011-03-23_14-34-16.png
