Help on Asus P4V533-MX Audio Driver
  1. Posts : 9
    Windows 7 Ultimate 32 bit
    I have tried many drivers downloaded from search engine results and asus's website.
    But none of them can work. It either turn the pc into blue screen or non-stop reboot.
    I hope someone can help
    Thank you very much!!
    Motherboard: ASUS P4V533-MX
    Thanks again!! :)
  2. Posts : 2,566
    Win 7 Pro x64 SP1 OS X Snow Leopard 10.6.7
    If you got a blue screen from installing the update for driver....
    https://www.sevenforums.com/crashes-debugging/96879-blue-screen-death-bsod-posting-instructions.html
  3. Posts : 9
    Hi DeanP, thanks for your fast respond! =]
    Is Windows 7 . . .
    - x86
    - the original installed OS on the system?
    no
    - an OEM or full retail version?
    oem
    - What is the age of system (hardware)?
    6years old
    - What is the age of OS installation (have you re-installed the OS?)
    Previously, I reinstalled two times with windows 7, the driver I found works.
    This is the third time, unfortunately I lost the driver.
    So when I download new drivers, all can't work.
    Help on Asus P4V533-MX Audio Driver Attached Files
  4. Posts : 6,879
    Win 7 Ultimate x64
    That motherboard has the Realtek ALC655 audio on it,
    ASUSTeK Computer Inc. - Motherboards - ASUS P4V533-MX
    the Windows 7 AC'97 driver from Realtek should work,
    Realtek
