stereo mix doesnt catch sound
  1. Posts : 13
    windows 7 home premium
    ok, i am trying to get sounds directly from comuter the weird thing is that.... when i open a sound recorder program it just have 2 options, microphone and stereo mix, when i put stereo mix it just dont record nothing, it is blank...
    there is any way for me to record sounds in win 7?
    thank you.
    there is a vid below that i created. so you can understand it better, (the microphone doesnt have sound cux it is desactivated, so it cant catch what speakers are saying )
    i have toshiba laptop, that might be somthing usefull.
  2. Posts : 9,582
    Windows 8.1 Pro RTM x64
    Hi sistemx and welcome to Windows 7 Forums
    Check to see that it isn't muted.
  3. Posts : 13
    no, it is in max..... just doesnt catch any sound..
    Attached Thumbnails Attached Thumbnails stereo mix doesnt catch sound-no-works.png
  4. Posts : 9,582
    Does the speaker symbol look like this stereo mix doesnt catch sound-capture.png (MUTED) or stereo mix doesnt catch sound-capture1.png (ENABLED) ?
  5. Posts : 13
    https://www.sevenforums.com/attachmen...1&d=1295868951
    as you can see.......
  6. Posts : 1,996
    Windows 7 Home Premium 64 bit
    What sound recorder program are you using?
  7. Posts : 13
    well
    it actually works with isound for windows 7 without stereo mix and that stuff (the trial version only let you 100 seconds..) , im trying to use audacity, but somehow it doesnt work.... and the oddest thing is that camtasia studio does record the sound if it is recording video.. BUT it lags, and when I try it to record sound only in camtasia it doesnt work..
    well i would like a program that can record unlimited, even on trial version, or a free software program
    or just fix that stereo mix
  8. Posts : 1,996
    I was able to record in Audacity by setting the preferences as follows.....
    Are your settings the same?
  9. Posts : 13
    yes they are the same...
  10. Posts : 1,996
    Have you tried disabling the microphone and try to record sounds on your PC with the Stereo Mix enabled?
