Sound Levels Constantly Changing on their own
Ok, I need a little help here. Lately, I have noticed that my sound levels in my Volume Mixer keep lowering to the lowest level.
I have an ASUS Rampage II Extreme MOBO that came with a Creative Sound Blaster X-Fi MB PCI-E Sound card.
The problem is, when I'm in a game or anything else, my "Applications" in the Volume Mixer most of them all go to the bottom. I can't get them to stay up top=loud. I have gone to the Control Panel>>Sound>>Communications and changed that to do nothing. (It basically says, windows can automatically adjust the volume of different sounds when you are using your PC to place or receive telephone calls.)
I am using a Logitech G930 and their software. I do believe it is some sort of software issue that is taking control of my audio, but not sure what.
Has anyone else experienced this issue?
Does anyone have a fix?
It bothers me cause when I am in a game, the game sound goes way down automatically and in the game settings, it is on High. I use Teamspeak a lot and have checked those settings and eveything seems to be fine.
