Windows 7: 5.1 surround sound help
24 Jun 2009   #11
Zaim
Windows 7 64bit RC2
Quote   Quote: Originally Posted by mustangman16 View Post
I've recently found out that my sound card application (creative audigy) is not compatable with win7 and have yet to find any creative programs that work with my computer. Is there a way around this to still be able to play music on 5.1 surround sound? Like a generic application to play music in 5.1? Or am i just being dumb?
hi there, try downloading this driver+software
SB Audigy Series Support Pack 2.0 (04/17/2009) - Sound Blaster - Creative Labs
24 Jun 2009   #12
stormy13
Microsoft MVP
Win 7 Ultimate x64
Zaim welcome to the forums.
Guess you missed the sixth post in this thread where I wrote,
Quote   Quote: Originally Posted by stormy13 View Post
First of all you XPS M1530 never had a Creative sound card in it, so installing anything from Creative is a waste of time. What it has is the Sigamtel onboard audio, and what you are trying to get to work is the Audigy (or even possibly X-Fi) MB software. What this is is a software package that Dell and a few others bought/licensed from Creative so that the onboard sound can use some of the audigy or X-Fi software, it in no way means that you can install the Creative drivers or any of the software directly.
Unfortunately your suggestion just won't work.
24 Jun 2009   #13
Zaim
Windows 7 64bit RC2
ah lol didnt see that. thanks for pointing that out
24 Jun 2009   #14
mustangman16
Windows 7 Build 7229 x86
Mine looks like an express card. It looks like there are screws right under my express card so i could investigate into taking it out and replacing it. Thanks a lot storm! Do you have any suggestions on an express card with 3 holes instead of the one you linked with only 2?
24 Jun 2009   #15
stormy13
Microsoft MVP
Win 7 Ultimate x64
Unfortunately that is the only one I know of, that and laptops aren't really my strong suit. Hopefully someone else on here will have a recommendation for you. Meanwhile while waiting it might be worth having a look around over here,
Notebook Forums and Laptop Discussion - Powered by vBulletin
and see what others are using and/or recommend.
24 Jun 2009   #16
mustangman16
Ya i've been looking things up and since i plan on buying a new computer when win7 comes out i might buy the usb one for convienance and its cheaper. Thanks a lot for all the help stormy. +1
-stang
22 Oct 2009   #17
Nyste
5.1 sound problems
Hi,I have a C-Media cm6501 sound card in my Asus M2N-E SLI motherboard and I have installed Windows 7 Ultimate (x86),I managed to configure everything to get the 5.1 system working,but the player,with or without codecs,does not play in 5.1,it just uses the two front speakers.I tested the speakers in the driver program and in windows in control panel,sound and it works fine but it stops there.I tried Winamp,Media player 11,Media player classic and 3 types of codecs and it's the same result,what can I do to make my 5.1 surround system work? I had Windows Media center edition(SP2) before and it worked fine.I also tried vista and I had the same problems I'm having with Windows 7.
Need Surround Sound
Hi all looking in vain for Surround Sound System, that isn't a dvd/Blu-ray player or a AV Amp System, just need it to work for sound 5.1 or higher with a sub out, optical in, is there such a thing ??? cheers web
how to get 5.1 surround sound through TV's USB
hi......i recently brought sony32EX650 LED TV with Sony DVD player with home theater.and i want to watch HD movies on this TV with surround sound but we know dvd player don't play the Hd quality videos.But on TV's usb we can play those Hd videos and they have 5.1 surround sound also.and i can't get...
Surround sound
Hi all. Upgraded my OS from XP to Win7 (again) Before I had just headphones.. Now I have problem. My sound card Realtek ALC883 @ VIA VT8237A High Definition Audio Controller Cpu AMD Athlon 64, 2200 MHz (11 x 200) 3500+ Motherboard Asus M2V-MX (2 PCI, 1 PCI-E x16, 2 DDR2 DIMM, Audio, Video,...
Help with Surround Sound
Hi. I have a ASUS LGA1156 Intel P55 DDR3 - 2133 ATX Motherboard I was told this mobo has surround 5.1 integrated with it. I just do not understand how to use it, or at least I think I don't. What cable do I need and what slot do i have to connect it to.
4.1 surround sound help
i have a 4.1 surround sound system on my Xfi card, my sub woofer is attached to my front speakers, and i wanted to know if anyone here knows how to dedicate all bass to one pair of speakers, that way i dont get such great bass from one side during my gaming, and a horrible bass from the other with...
