hi there, try downloading this driver+software
SB Audigy Series Support Pack 2.0 (04/17/2009) - Sound Blaster - Creative Labs
Mine looks like an express card. It looks like there are screws right under my express card so i could investigate into taking it out and replacing it. Thanks a lot storm! Do you have any suggestions on an express card with 3 holes instead of the one you linked with only 2?
Unfortunately that is the only one I know of, that and laptops aren't really my strong suit. Hopefully someone else on here will have a recommendation for you. Meanwhile while waiting it might be worth having a look around over here,
Notebook Forums and Laptop Discussion - Powered by vBulletin
and see what others are using and/or recommend.
Ya i've been looking things up and since i plan on buying a new computer when win7 comes out i might buy the usb one for convienance and its cheaper. Thanks a lot for all the help stormy. +1
-stang
Hi,I have a C-Media cm6501 sound card in my Asus M2N-E SLI motherboard and I have installed Windows 7 Ultimate (x86),I managed to configure everything to get the 5.1 system working,but the player,with or without codecs,does not play in 5.1,it just uses the two front speakers.I tested the speakers in the driver program and in windows in control panel,sound and it works fine but it stops there.I tried Winamp,Media player 11,Media player classic and 3 types of codecs and it's the same result,what can I do to make my 5.1 surround system work? I had Windows Media center edition(SP2) before and it worked fine.I also tried vista and I had the same problems I'm having with Windows 7.
