Static on built in Conexant Microphone
  1. Posts : 3
    Windows 7 Home Premium 62bit
    I just got this computer one year ago, and my microphone was just fine until I did a certain update and it suddenly had alot of static in the background. Is there any way I can reduce this? If so, what must I do? :)
    Attached Thumbnails Attached Thumbnails Static on built in Conexant Microphone-computer-stats.jpg
    First suggestion, go to the Device Manager, RIGHT click to higlight the enter for the sound device the LEFT click and "uninstall" the device. DO NOT check the box to uninstall the drivers. Restart the PC and when Windows starts it should detect and reinstall the sound.
    If this does not fix it, get the latest sound driver from HP and install that.
  3. Posts : 3
    But how do I get the latest sound driver from HP?
  4. Posts : 8,135
    There may be a link provided by HP (HP Owns Compaq) on your PC. If not HERE is the link to the HP support page. You enter your product model number and it should take you to the support page for your model including driver downloads.
  5. Posts : 3
    It didn't work for me. What should I do now?
